2013 Oil Leak and Burnt Oil Smell
We’re looking at a 2013 RTS SE5 that belongs to an elderly friend of ours. He’s the original owner. It’s been in storage in a heated rv and car garage for about 3 years. When we went to test ride it I knew to check the oil we had to warm it up, so we idled it until the cooling fan cycled twice. Oil was half way on the dipstick. But during this warmup it started smoking like oil burning off an exhaust manifold. I’ve built several car engines and it smelled just like oil burning off a manifold or header pipe. Oil was a honey-amber and looked “clean” on a white paper towel. There was a receipt for an oil change 400 miles before he parked it. I’ve got impressive smoke videos but can’t post them. I took a screen shot of the smoke and will attach it. I’ve booked it into the dealer for an inspection and diagnostic on November 26th. Are there rubber lines to the oil reservoir that could be leaking? I’ve parked it on clean concrete and will check for drips in a few days. We pulled the left and right covers and didn’t see any obvious oil leaks using a flashlight.the condition of the machine seems to be great other than this. If if makes a difference, it’s yellow
https://youtube.com/shorts/pbVFbKMjwN0?feature=share
Reason: Adding YouTube link
SpyderLovers Ambassador
Burnt Oil Smell
... Just a few questions.
1. Did you see any signs of oil or something else
on the engine?
2. Were you able to see every part of the engine?
3. How long did you run the engine?
4. Did you ride the Spyder?
Nice color by the way.
Post Up some more information so we can try
and help you out.
Stay Healthy. ....
ENJOY YOUR LIFE WITH A SPYDER
My Spyder ..... 'Little Blue-Boy'
Reply to oil leak questions
Answered the questions below after each question. Hope his works, still very new on this forum.
on the engine?
No. It was dry where we could see and the coolant tank looked good.
No. Only what was visible from taking off the two panels over the oil tank and opposite side similar panel.
20 minutes. Enough to get it up to temperature and cycle radiator fan twice.
Yes about two miles. Limited the ride to 1&2 gear 30 mph. We were worried about a fire.
The owner let us take the Spyder on a trailer to the dealer where he bought it to get it looked at to see what’s wrong and leaking. The dealer said they can’t work it in until November 26th so it’s in our garage till then. 33548DEC-6E33-4119-834A-B5710517C65F.jpg
and help you out.
Stay Healthy. ....
Letting the engine idle til the fans cycle twice is not long enough to get an accurate oil level; coolant gets up to temperature much quicker than oil. You need to take it out for 10 to 20 minute ride before the oil gets warm enough.
If the oil level was half way up the dipstick the way you idled the bike it's possible it was overfilled during the last change. That could cause excessive smoking.
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
Ozzie Ozzie Ozzie
The Spyder does have the heat mitigation (under mirror) inlet scoops installed, riding at speed would be forcing more cool air around the engine compartment, hoping that all the other heat mitigation was done on that '13, it should be safe to ride more and get an idea of where the oil issue is. Living up north, I only put 38K miles on my '13 (bought used in '16, replaced in '22) before upgrading, but Loved that ride! Go ride and enjoy. Though, if the previous owner didn't replace the vacuum lines and or sparkplugs and wires, it might be time for them to be serviced, those and brakes and tires were all I really needed in 5 yrs of riding my '13.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
See my Spyder Garage
IBA 70020 |
I know that this sounds wacky, but check the oil filler cap, make sure it is on correctly and fully seated. This happened to me after an oil check, oil was blowing up the fil and getting down onto the engine. Smoked like a mother. pulled all the Tupperware off and boy did it stink. It took 3 cans of BreaKleen to get it off, but it worked. I only had a minor heart attack.
"Champagne Dream"
2017 Champagne Metallic RT-S SE-6 Rivco Dual Flag Holders & Highway Pegs; Airhawk Seat Cushion; Show Chrome Black Touring Rack w/ Risers & Touring Windshield; RAM X Mount For TXTAG; TackForm Phone Mount; Lidlox; Magic Mirror Mounts; Guardian Bells; WOLO "Bad Boy" Air Horn; Dual USB Power Outlet With Voltmeter; Spyderpops Full View Turn Signals, Large Brake Pedal, Kott Grilles; Large Mud Flap; BajaRon 3 Piece Sway Bar
2017 RT-S , Stock Brake pedal extender is twice the size of the stock pedal. Champagne Metallic
In an aggregate answer to several questions.
All the engine areas we could see by taking off the two panels over the oil tank and opposite side panel were dry no indicator of anything wet.
The oil filler cap was on correctly.
The heat recall modification was completed at the 600 mile service.
Since we haven’t bought it pending the dealers inspection, I’m reluctant to take off more Tupperware.
But it’s definitely burning something off the exhaust that I think is oil.
https://youtube.com/shorts/zxCWQRLKMXM?feature=share
And sit down ,take a breath,,,,,,
Total miles is just over,,,,,,,,
1070. Nota typo.
Reason: Add videolink
Ozzie Ozzie Ozzie
1070. Nota typo.
So would the owner object if you rode it 50 miles or so, cos I reckon that'd likely burn anything left completely off the pipes/other hot bits, and may well make the dealer's inspection more of a cursory check over & a bit of a moot point?!?
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Test ride.
I’m sure he’d be ok with that. I’d just worry that something would go wrong.
Reason: To delete video clip
I would suspect a rodent nest near or around the exhaust pipes.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Ozzie Ozzie Ozzie
Reason: you you... :-/
DIY or Pay the Dealer?
...If you can/feel comfortable about checking out this Spyder yourself, you will save a lot of money. My Dealer said that they would charge $150.00 an hour. This type of work would be 2 or 3 hours just for the labor.
It is your choice and your money. Everyone has posted up good Tips. Over to you now.
Good Luck on Your Mission and let us know how everything turns out.
Stay Healthy. ....
