Anyone have problems with Tricled Peel & Stick Wide-Vu Mirrors?
2022 Spyder RTL. Ordered these mirrors from Slingmods. When trying to dry fit these I found that the plastic rim on the back of the add on mirror was a bit too small to fit over the factory mirror plastic rim without a lot of pressure applied. i called Slingmod and they're going to contact the manufacturer. Some reviews of the product on Slingmod said one guy has one of his mirrors fall off. Another said he sanded down the rim on the add on mirrors (sounds very messy). Another said he added two sided tape to the top and bottom.
I hope this part makes sense. If the add on mirror is "flexed" to fit to the factory mirror it's going to have pressure from the bend trying to pull it away. Adding tape to the back seems like there would be much less contact with the adhesive that's already on the mirror.
Any have this problem and a solution?
Thanks y'all.
Reason: Revised title to briefly ask the question... ;-)
