Results 1 to 7 of 7
    Oct 2017
    Winchester, VA
    Default 2022 RT Rear Shock Losing Pressure - my fix!
    I had a problem with the rear shock on my 2022 Spyder RT losing pressure. I called my dealer and they said they’ve had several calls about this.
    I found my problem and an easy fix. My valve stem core was slightly loose. I used a valve stem tool and tightened the core. Problem solved.
    I told my dealership about this to pass on the info.
    Last edited by Peter Aawen; 10-21-2022 at 06:22 PM. Reason: Removed Prefix - this is not a 'How To: DIY' guide. ;-)
    Active Member USAF's Avatar
    Aug 2022
    NY
    What were the indicators that it was losing air ?
    2022 Spyder RTL
    Oct 2017
    Winchester, VA
    Quote Originally Posted by Rick28 View Post
    I was bottoming out and then checked the pressure
    Feb 2016
    The old school way to check this for leakage is to remove the cap and place a finger full of saliva in the schrader valve. If it blows bubbles, it's leaking.
    2020 RT Limited , Marsala Red
    Feb 2020
    Minnesota,USA
    My dad showed me that trick 65 years ago on my bicycle, have used that advice ever sense......Bill
    If in Doubt, Don't Do It!
    Harrington, Australia
    Thanks very much for the heads up, Therris
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2021
    Wichita, KS
    Peter Pan has struck again!
