2022 RT Rear Shock Losing Pressure - my fix!
I had a problem with the rear shock on my 2022 Spyder RT losing pressure. I called my dealer and they said they’ve had several calls about this.
I found my problem and an easy fix. My valve stem core was slightly loose. I used a valve stem tool and tightened the core. Problem solved.
I told my dealership about this to pass on the info.
Reason: Removed Prefix - this is not a 'How To: DIY' guide. ;-)
What were the indicators that it was losing air ?
I was bottoming out and then checked the pressure
The old school way to check this for leakage is to remove the cap and place a finger full of saliva in the schrader valve. If it blows bubbles, it's leaking.
2020 RT Limited Deep Marsala Chrome
My dad showed me that trick 65 years ago on my bicycle, have used that advice ever sense......Bill
2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
BaJa Ron Ultra 3 pcs sway bar kit
7jurock 25" tinted windscreen w/flip
Frogman Dave's "Signal Button"
If in Doubt, Don't Do It!
" Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
Thanks very much for the heads up, Therris
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Pete
Peter Pan has struck again!
