Results 1 to 7 of 7
Hybrid View
    Dec 2015
    South Carolina
    Spyder 14 inch rims on a 2022 with 15inch rims
    Just wondering, could I run my custom 14inch front rims on a 2022 rtl that comes with 15 inch rims. What would be the negative ramifications?.
    Bossier LoUiSiAna
    Probably a number of things -nanny quite strict -only what she knows &no slack ABS too
    Linden, CA
    Quote Originally Posted by Indiana Ken View Post
    I doubt you could get them on over the brake calipers
    THAT's probably gonna be your biggest issue! One of the major reasons the 2013 & on Spyders have 15" rims is to clear the Brembo disc & caliper combo!
    Besides, why would you want to go to a 14" rim anyway?? Even if they DID fit over the brakes, no matter HOW purdy your 14" rims might be, those tiny dinky rims teamed with a tire that'll fit them will make your Spyder look oddly unbalanced & the wheel wells empty, & likely cause a bunch of associated Nanny issues due to the size imbalance; and if you fit those 14" rims with tires that have an even higher profile so that they get anywhere like reasonably close to the fenders, there'd be a good chance you'd still cause Nanny problems by running tiny rims with high profile tires up front with all the different handling characteristics that entails - ie, you'll also likely introduce all sorts of performance & handling issues that the BRP Engineers tried to design out by fitting larger dia rims with (slightly ) lower profile tires in order to minimise things like tire tuck & scrubbing & tread lift & ....... yeah, the list goes on!!
    Basically, with the advent of the 2013's (that were originally intended to get the 1330 motor) there's the necessary rim size increase to fit the larger/better brakes the heavier motor necessitated; AND then there's all the tire related ride, handling, & performance advantages of running a larger dia but lower profile tire; teamed with the suspension changes designed to maximise the benefits of running said larger rolling dia rim/tire combo; PLUS there's the Nanny upgrades that cater for all those tire & brake & suspension & any other improvements besides - so overall, you probably just wouldn't LOSE any advantages all those upgrades bring; but there's a very good chance your Spyder's handling & performance et al would be WORSE - ie, degraded to something even less than that of the earlier Spyders....
    But all that said, it is your Spyder.....
    Dec 2015
    Oakley Utah
    Why don't you try it and let us know.
    2014 RTL Platinum
    OH MY! Logic! What is this world coming to!?
    Sep 2016
    Chillicothe, Oh.
    Somebody has to bite the bullet and go first Hold my beer and watch this!
    2015 RT , Black
