2010 RTS Display keeps resetting - Any ideas why?
Hi,
I just got a 2010 RTS and some of the time the display/computer will just keep resetting. It was flash "Can-Am", flash white and repeat for mins . Other times it will do it once and go in .
Here is a 7min video of it happening: https://drive.google.com/file/d/1DSP...w?usp=drivesdk
Update: after some testing, this only starts happening after the engine has been running and you shut off and turn on the ignition again...
Any help will be appreciated.
Thank you
Rich
Reason: Removed Prefix - not engine/size related
Ozzie Ozzie Ozzie
Had this same issue our 2011 RTS back 3 years ago. The center screen would show horizontal lines and reset, Along with the speedo and tack gauges. Its an internal issue, You have to replace the entire center cluster. fairly easy fix. But get ready to shell out about $1000. Oh and the mileage goes through that as well so if you can ever get your old one to work remember the mileage because that is where it is stored. When you replace it you will have a "zero" mileage cluster. For us, ours went out just before 10k miles.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
