Will a Seat from a 2019 RT go on a 2011 RT?
My question is:::::
Will the 2019 RT seat fit my 2011 RT.
I’ve read it it appears that it will work but wanted to ask before buying it.
Greg
Reason: Expanded Title to briefly ask the question ;-)
Greg
2015 RT Limited (White)
Ozzie Ozzie Ozzie
YES!
There may be some (relatively minor) variations in the moulding of the plastic pan underneath, but it'll fit & work well. You won't be the first to have done it, either - others have been the Beta testers for you already!
Originally Posted by Wrongway
My question is:::::
Greg
Yes it will fit. The only difference is the 2019 will have a built-in mount for the stock driver's backrest, should you choose to install one.
The 2011 seat requires you to cut into the seat to mount a backrest.
IBA #47122
2020 RT Limited Asphalt Grey
Ozzie Ozzie Ozzie
Thanks everyone. Your responses are greatly appreciated.
Greg
