Results 1 to 10 of 10
    Aug 2022
    Ohio
    Default Anyone else bending Keys??
    2022 RTL LIMITED my first key was bent so I tried to straighten it and it broke.
    Used my 2nd key 2 times and it’s starting to bend. Has anyone had this happen to them?
    Bossier LoUiSiAna
    Almost but stopped issue was the ignition could push in for some features (seat -frunk- fork lock) opposite of lock on my two wheeler. Matter of self training. Just try & slow down
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Dec 2013
    There's over 110,000 Spyders out there now, and while there's been a few reports of bending/breaking keys over the years, it's a tiny, tiny percentage!! So, either this issue is something new with the 2022's (haven't seen too many others - yet! ); there's something wrong with the working stuff behind your key/ign, making it difficult to turn (seen a few of them already! ); or you are doing something wrong (see post above!! )
    I'd be looking at making sure any/all the cables behind the ignition (frunk & seat openers, fork/steering lock?) are suitably lubricated & adjusted properly - which should be a warranty fix; &/or watching very carefully to make sure there's nothing you're doing that could be stressing the key! But while you're at it, get your working key duplicated/cloned if you can - again, I'd expect that to be a warranty issue, since the originals haven't been able to do the necessary job without breaking!
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    This EXACTLY why all the cables on my ignition switch have been removed ( many years ago ) and replaced by separate cables to release Seat and Frunk ..... good luck ... Mike
    Aug 2022
    Ohio
    thanks to all for the advice
    Jul 2014
    Mint Hill, NC
    As Peter said, you've a warranty issue. Don't let the dealership screw you out of doing their job.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Mike, I would be interested in seeing a picture of your revised Frunk cable. I recall you mentioning this mod before, but I never thought to ask back then. TIA.
    Rick
    2014 RTS Pearl White
    2014 RTS , Pearl White
    Oct 2021
    Wichita, KS
    I have not noticed an issue with this on my 2022.
    Peter Pan has struck again!
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    i have noticed on my 2022 rtl there is a fine line between turning on the ignition and the depress to unlock seat and frunk.
    that fine line and the key won't turn.
    what i do is insert key let go of it then turn to ignition on/run/start/launch whatever were calling these dayz
    Quote Originally Posted by Briorick View Post
    Rick
    Sorry I don't have a PIC of that ..... however where I attached my release cable on the Latch Arm was based on what a fulcrum does. I put the cable at the very end of that Latch arm ..... A very, very small tug on the cable and the Latch opens. As a child a read about what a Fulcrum can accomplish .... the example given was , if you a long enough rod and used the Moon as the fulcrum point a man could move the earth from it's orbit ...... Yes I know this isn't actually possible however it would work ..... Mike
