Page 1 of 2 12 LastLast
Results 1 to 25 of 38
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Default Has anyone got the permanent fix for their sprocket?
    I called my dealer to see if they had the permanent fix ready. He told me BRP is not allowing them to stock parts, I would have to bring the bike in and have them take a picture or it. Then LEAVE the bike until the part comes in because they can't stock the part! I would also have to pay for them to put the bike back together after assembly because they only get paid to take it apart.
    I have never had to take a vehicle in for a recall so please tell me this isn't they way business is done (especially when it's their fault!)
    Sounds like another "smooth move" by either BRP or another lying dealer.
    Bring the bike in so they can take a picture? Leave it with the dealer until they can get the part to fix it? How about those six week wait times and delays that the dealers are foisting on the public? Anyone looked at the calander? Winter layup is coming for many. Is the dealer going to keep the Spyder all winter, to do who knows what with it?
    Hope my attitude and temper is not showing to much.
    Feb 2019
    Central WI
    I tried 3 other dealers (a lot farther away) who said they don't have the parts yet? What the hell, I have no idea what was up with the dealer I called. Are certain dealers getting parts before others? I don't think you have a bad attitude at all, I am ready to tear down the BRP and spyder signs I have in my garage! I in no way want to promote this stupidity.
    Dec 2020
    Hartwell, Ga
    As far as I know, nobody has the fix yet. and it might be next year before they do. There are several other threads on this exact topic.
    Honestly, I don't think the BRP knows what the fix will be.
    Also, stay away from that 1st dealer, sounds like a total rip-off. I'm not a lawyer but, I don't think you can be legally charged for a recall like this.
    Northern Kalifornia
    Simple solution. Correct me if I'm wrong. Order an early 14 or pre-14 sprocket. I'd think they would all be the same size as later units.
    Feb 2019
    Central WI
    Quote Originally Posted by K80Shooter View Post
    Thanks, I did a search on past posts, but found no one who actually got a fix - that is why I posted a new thread to see if my dealer was right. Also you are correct - if you look at the back of the recall notice it says that this should be remedied without charges!
    Idaho
    Good luck trying to do that. The sprocket for all RTs from 2014 to 2022 is the same part #, which replaces original part # for all years from 2014 to Sept 2020. The part # was changed in Sept 2020 so that must be the one they are planning to use for the recall replacement. That # is 705503239.
    2014 Copper RTS
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    I got the recall notice months ago, but based on what I've seen here on SpyderLovers I am NOT taking my Spyder in for the preliminary service just to avoid the situation of being told not to ride it at all until the permanent fix is ready. Nobody knows when that will happen either. It's long past the original estimate.
    I'm not having any visible problems with the sprocket, or any unusual vibrations, so for now I plan to ride until the "fix" is actually available.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Northern Kalifornia
    Thanks, I should have known that but it was just a hopeful thought for those in need.
    May 2013
    Apex, N.C.
    I just got off the phone with my local dealership and explained to him that I had 2- 2016 bikes. I check them before each ride that will be over about 200+ miles, and also about every 1000 miles. I asked if they needed to inspect it and if the fix was in the works or if I should come in for a "temporary fix". He said what I am doing now was my best bet and no real fix is available. Just call about each month and when something is available, they would set up a time for the replacement.
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    In my opinion, the definitive repair will bef a pulley change to one that is not yet available.
    I base my opinion on the fact that the change is not made to all Spyders but only to some series of some models of some years, giving me to understand that they are "defective parts" and that is why they will change them, but not for "new old model pulleys" but by "new pulleys of new design or manufacturer".
    Here in Spain I have passed a review in which the distributor tried to see the existing play between the shaft and the pulley without being able to move, so we remain calm while waiting for the arrival of the new solution.
    Obviously, both this first review and the final one will be in charge of BRP. Another thing is what the dealer get for the work, which is almost always too little, but that is not the end customer's problem and they must solve it among themselves.
    2018 Spyder F3 Ltd
    2018 F3 Ltd. , Black/Dark
    Active Member USAF's Avatar
    Aug 2022
    NY
    What years are affected with this issue ?
    2022 Spyder RTL
    Nov 2013
    Central Texas
    Yeah, my dealer says at least 3 months before they get the parts, if then. My Spyder passed the inspection (read interim repair) and I check the sprocket regularly. The OP's dealer telling him that he has to pay for re-assembly shot my BS meter to maximum red. Once again, BRP is nowhere near being really prepared for this. It would be interesting to know where the sprockets will be manufactured, as I don't think any have yet to be. And that's on BRP for not being aggressive in sourcing the part. Reminds me of the 2013 RT heat recall-I had a 2013 RTS- and waited several months for the parts to become available. It p****s me off that we pay so much money for these machines and once BRP has our money they don't care about us anymore. One would think that they would keep dealers updated, but as we all know, they NEVER do that. Dealers are as much in the dark as we are.
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Rick28 View Post
    Not trying to be rude but you really do need to use the search function. This is just one thread on the issue.
    https://www.spyderlovers.com/forums/...Recall-FINALLY
    Peter Pan has struck again!
    Sep 2013
    Houston
    Quote Originally Posted by MonPaul View Post
    I will make this easier for you. Your dealer is feeding you a bad line of BS in hopes you will just go away.
    Replacement sprocket for the permanent fix is not yet available and cannot be ordered.
    Your dealer can order and stock any parts they want to spend money on.
    The recall is to be performed at no cost to the owner for parts AND labor.
    The currently available part number is NOT the final fix
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Northern Kalifornia
    Not all dealers are responding to this sprocket situation the same. Some are reacting very badly. Those who do, are displaying their true feelings, creditability, and dedication to their customers. I for one, can not understand their reasonings. After all this situation is not of their making. JMHO
    Feb 2019
    Central WI
    That's why I was asking! It sounded exactly like that, they were doing anything they can to make it difficult in hopes of you going away. I am going to contact BRP and even the administration that sent me the letter. Nothing will probably get done but I hope someone at least contacts them.
    Idaho
    Replacement sprocket for the permanent fix is not yet available and cannot be ordered.......The currently available part number is NOT the final fix
    Something's not adding up to my way of thinking.
    Part # 705503239 is the currently available sprocket, according to the BRP parts catalog.
    The catalog shows that 705503239 was used starting in Sept 2020. That means it was not used in 2020 models.
    2014 and 2020+ models apparently do not have a fretting problem.
    The part number changed from 2014 (705501986) to 2015 (705502134) so who knows what changed in the material used?
    According to the BRP parts catalog the *2134 sprocket was used up to Sept 2020.
    If there was a significant difference in the sprocket material from 2014 to 2015 was that the cause of the fretting? If so, why don't we see reports of fretting with the 2020 models and why are they not included in the recall?
    That's why, as I stated in another thread, I'm thinking the output shaft may be the cause of the fretting. But if so, then why don't we see reports of fretting with the 2020+ models since the output shaft part # is the same from 2015 to 2022? Or did they (or Rotax) make a change in the output shaft in 2020 without changing the part #?
    My observation has been that quality control over documentation has not been one of BRP's strong points. Maybe one of the reasons they are taking so long to come up with the permanent fix is there have been material or manufacturing changes in the sprocket or output shaft that were not identified by part # changes. Maybe they simply do not know what sprocket material is in the sprocket of every Spyder since 2015 and so have been unable to pinpoint the root cause of the fretting. And if they don't know the root cause, there is no way to define the fix.
    All of the above emanates from my years working in quality assurance where I came up with the following mantra; QA-QA-QA -- The Questioning Approach of Quality Assurance leads to the Quintessential Answer!
    2014 Copper RTS
    Jun 2015
    Ritzville, Wa
    I may be living in some kind of Leave It To Beaver, Father Knows Best fantasy world, but isn't putting the bike back together again part of the repair process?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Dec 2020
    Hartwell, Ga
    Even if someone from BRP contacts them you can rest assured that your information will be passed on to them.
    Would you really want them working on your Spyder with them knowing that you reported them? I wouldn't.
    Nov 2019
    Kansas
    I replaced my front sprocket earlier this year. As far as I am concerned, My bike is completely fixed and not worrying about the recall.
    Plus nobody should ever pay any money when a recall is in play.
    2018 F3 Limited
    Feb 2019
    Central WI
    That's the first question I asked and he told me they would do their own internal investigation and my name wouldn't be mentioned. It really doesn't matter anyway because I don't ever plan on going back there. Also I think being afraid they use my name is not the right attitude to have, I am trying to stop them from ripping other people off!
    Dec 2020
    Hartwell, Ga
    You must have taken something I said out of context. I never said you should be afraid to say anything, I strongly recommend you or anyone in this kind of circumstance to say something.
    All I was saying was I wouldn't want them working on my stuff again. And that they would know who reported them (unless you gave them a fake name or something like that.)
    Jan 2019
    Kentucky
    Some dealers charge extra fees for everything. My original dealer was like that. When I had warranty work done they charged extra fees. Find another dealer you can trust. Those are Stealerships especially when your recall letter says "BRP will repair your vehicle at no cost"
    2015 Spyder F3S SE6
    Northern Kalifornia
    Is it possible to find out who and where these sprockets are made?
