Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Joe
    2023 F3
  2. #27
    Mar 2020
    Western New Mexico (Thoreau)
    Thank you so much for listing the link! I am not knowledgeable when it comes to doing such things!
  3. #28
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Quote Originally Posted by Don60 View Post
    If you do the work yourself, you may have trouble with the throttle dragging. You have to be careful not to over tighten the screws on the new collar.
  4. #29
    Aug 2016
    Maine
    Good Day
    talked to the service rep at the Can Am dealership. He told me his mechanic said that he can't put the cruise control assembly on my 2018 Spyder F3. Are they just saying this to discourage me from getting the cruise control?
  5. #30
    Mar 2020
    Do not think your Controls on your F3 are different than mine? Part # listed above should fit! If you have the option, might check with different dealer! Sounds like they just did not want to, or know how to replaced the right side control? Good luck.
  6. #31
    Mar 2022
    Maryland
    Default adding Cruise Control
    Quote Originally Posted by stovebolt_six View Post
    Here is the part number you need: 710004146, cost me just a tad over $200 from the dealer, 2 1/2 hours worth of time, and some assistance from my lovely wife, and we now have cruise!!!!
    Does anyone have a video to watch to do this im definitely need cruise control
  7. #32
    Aug 2016
    Maine
    This is the only one I've found. Not that great, but you get the idea.
    https://www.youtube.com/watch?v=zh9Azn_WHkQ
    PART 2
    https://www.youtube.com/watch?v=S_HHtK2_-IA&t=870s
  8. #33
    Mar 2020
    Please check out how to install cruise posts. Should be one that gives you an overview! I did one on a 2020 base F3, plug and play! I removed complete top panel/ nose of bike, including speedometer. Took my time when removing and installing new end of cable, very tight fit if you use OEM path. Well worth the approx. $230.00 for new module.
    2021 Spyder RT-L - Asphalt Grey
    • Vredestein tires all around
    • Rolo Laser Alignment
    • Lamonster tire balancing rings/front
    • Lamonster Sway Bar
    • Lamonster belt tensioner
    • K and N air filter
    • Rear cowl - in place when you remove rear box
  9. #34
    Aug 2018
    Columbus
    Default F3 base adding cruise control
    Are there any base model f3’s that you cannot add cruise control to? I am looking to upgrade from my ryker to a F3 (or F3S) but I am looking used for budgetary reasons. I found a used base model 2019 base f3 and the owner very clearly states in the ad that there is no cruise control, probably a question he has been asked many times. Can cruise control be added to it? If so, how difficult is it to do yourself?
  10. #35
    Quote Originally Posted by delkhouri View Post
    Answering the bold bit in order; YES, it can be added; and once you've got the right bits, if you can plug in a wiring connector & turn a screwdriver, then it's that easy!
    IIRC, with the F3's, because the wiring loom is common across the entire model range & the ECU's are all basically the same, the wiring & cruise control capability is already all there; it's just that the RH Control Module doesn't have the switch for the Cruise Control. That switch is missing on the base model Control Modules, so to get Cruise to work, you either need to fabricate a switch yourself & wire it in/connect it up (might be a tad hard?!? ) or take the easy way out, pay your money & source an OEM RH Control Module, then fit it, plugging the wiring in when you do, & away you go, Cruise Control is installed & now functioning!
    If you do a little bit of searching & some light reading, there's a few threads here from people who've done just this to their base model F3's; I believe there's even at least one person who's gone with the slightly harder former option.
    Over to you! Good Luck!
  11. #36
    Active Member MrSchaefer's Avatar
    Jan 2020
    Minneapolis, MN
    Yes it can be done - I did it on my 2013 ST.
    Easiest way is to buy the control pod from the right-hand handle of a F3T or F3L and then trace the wires back through the body. Beyond that it is plug and play. Below is my video of doing this on my ST for reference.. the process will be largely the same, just.. different body work obviously
    2021 Spyder F3-T - Pearl White
    2021 F3-T , Pearl White
  12. #37
    Aug 2016
    Sun City West, AZ
    Technically it’s easy. In reality feeding the enormous plug through the bodywork is a royal pain. Pay the dealer an hour to do the work and save the headaches.
  13. #38
    Mar 2022
    Colorado
    Default Can a BRP Cruise Control be installed on 2022 F3 Paddle Shift?
    Can a brp cruise control be installed on the basic f3 ? It has a paddle shift
    Last edited by Peter Aawen; 02-26-2023 at 08:09 PM. Reason: Changed title to reflect OP's shift edit. ;-)
  14. #39
    Mar 2017
    Salisbury,NC
    They are NOT manufacturing any more manual shifts. All semiauto, at least from 2020
  15. #40
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    There has been discussion about this and it said you can add the cruise. The bike has the same main harness for the F3 and the F3S that comes with cruise.
    Obviously you need the right handlebar cruise control unit. Don’t know what else. Am sure some other members will contribute their expertise.
    2015 F3S SE6
  16. #41
    Jul 2015
    Colorado
    I purchased the right handlebar cruise control unit from BRP for my 15 F3 base model, in approximately two hours worth of time, I had cruise control. Plug and play.
    2015 F3 , OEM None Black
  17. #42
    May 2023
    Tucson, Arizona
    Another cruise control question. Sorry.
    I have a 2018 F3 base model, and I understand I can add factory cruise control by simply adding a F3 Sport or Touring RH switch housing.
    However, in searching Spyder forums, I come up with different part numbers. I think one part number may have superseded the other.
    Does anyone know the correct part number to order , and , if you know who has the lowest price on this part, I would appreciate you efforts very much!
    Thanks!
    Brian in Tucson
    Last edited by Peter Aawen; 07-08-2023 at 09:12 PM. Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
  18. #43
    Quote Originally Posted by brian10x View Post
    Thanks!
    Brian in Tucson
    Go to any of the after-market parts sellers ..... type in the number/s you have and then click on " what years & models they are used on " .....Mike
  19. #44
    May 2013
    Gladys, VA
    Adding Cruise Control to 2023 F3 Base
    Any owners of newer model F3 Base Spyders had success with adding cruise control????
    Thinking of picking up a 2023 F3 Base but the only thing would be missing is cruise control. Did a search on here and the web and see that others have added cruise to their Spyders --but they were older models. Pretty much a plug n play install. Have not been able to find any info on the newer models. The RH Switch Housing #710004583 off a 2023 F3-S should do the trick.
    Figured I would ask here first before I checked and asked around at some dealerships.
    Last edited by Peter Aawen; 07-17-2023 at 07:30 PM. Reason: Moved Post title into text after merge - many only see Thread titles, and post titles mess with Searching! ;-)
    Joe
    2023 F3
  20. #45
    Oct 2011
    Kalamazoo, Mi
    Yes Joe, all you need to do is replace the right hand switch controls with one that has the cruise switch. Then just unplug your old and plug in the new ad volia you have cruise control!! Oh and about $ 400.00 less in your bank account!!!
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
  21. #46
    May 2013
    Gladys, VA
    Thanks for the info Al. Just ran across a review that someone with a 2020 F3 base that switched them out and worked fine. Looks like the RH Switch Housing #710004583 will set me back $275.
    Joe
    2023 F3
