Results 1 to 8 of 8
    Jun 2011
    Near Lexington, NC
    Default Are Belt Tensioners installed on new bikes same as they used to be?
    Just wondering if BRP had updated them when they began installing as a factory build, as opposed to those they used to sell as an accessory? Can't seem to find them on the fiche to compare part numbers. Just a matter of curiosity on my part.
    FWIW, I've read all the pros/cons about use of the belt tenioners. I recently added an OEM that I bought a couple years ago but never got around to installing, on my '16 F3T and it works for me. Plan to update to a Lamonster version sometime soon.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2021
    Haven, Ks
    All I know is from personal experience. I took delivery on a new 2022 Sea to Sky and I checked it and found a factory installed tension-er already in place. Prior to this bike I had a 2019 RTL and installed a Lamonster version which worked for me. I will replace the roller on the new bike with Lamonster replacement after a while.
    Bartender
    2022 Spyder Sea to Sky
    Active Member USAF's Avatar
    Aug 2022
    NY
    So the new Spyder RT's come with them from factory ?
    2022 Spyder RTL
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    My 2021 F3-S SS came with a belt tensioner from the factory.
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Ultimate Floorboards
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Rick28 View Post
    Mine came from the factory with one, Rick. I believe that practice started with the ‘21 RT.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2021
    Wichita, KS
    Pete
    From what I have read on this forum the '21's had them about mid year. I think the early year builds did not have them. I'm not for sure on that. My '22 does for sure.
    Peter Pan has struck again!
    Jun 2016
    Quote Originally Posted by FrogmanDave View Post
    Yes, that sounds familiar, Dave. Mine was a later built 2021.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Let's get back to the original question. Are the belt tensioners now installed by the factory different from the ones BRP was selling to us as an add on?
    Happy owner of 2014 White RTS - SE6
