Results 1 to 17 of 17
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    Default A front wheel WILL come off the ground (I found out this weekend)
    I was sort of shooting a gap to make a left turn at an intersection. We were probably going only ~10 mph (I'd guess). I was in a low gear, made a sharp left as I hit the throttle. The front left wheel came off the ground.
    I hadn't experienced this before. I quickly backed off the throttle and brought the wheel back down with a bit of a bump (my wife thought we just hit a bump ... no idea what that "bump" was until I told her.)
    Still having some new experiences every ride ...
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    Sep 2020
    Middletown, NJ
    Easy to do that when making a tight turn and gassing. Almost like a half-wheelie. Best to ease the throttle on until you're pointing straighter.
    2020 RT base , Chalk White
    Mar 2017
    Salisbury,NC
    If wheel came off ground, VSS icon would have showed on screen. After you gassed it , wheel off ground, VSS, throttle should have been cut
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Could that be called a nanna nap
    Kenda wars survivor
    Registered crackpot
    Informed consent
    ''Experts" say eating red meat makes the sun hot
    2017 F3S Daytona , Circuit Yellow Metalic
    Dec 2020
    Down South
    Huh? Your left wheel came off the ground while making a left? Sounds exciting.
    '20 RT Chalk Metallic
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by GRHorst View Post
    Same happened to us and in the same situation. Hard left turn and on the throttle hard. I figure it happened quickly and the left wheel was still turning so Nanny saw no difference in the wheel speeds and at that slow speed there wasn't enough centrifugal force to trigger those sensors either. If the rear tire had broken loose Nanny may have jumped in, but whatever surface I was on the Altimax bit hard with no spinning. Electronic safety gadgets are great, but if you bet your life on them it may be the last bet you ever make.
    2015 RT , Black
    Dec 2013
    Quote Originally Posted by Navydad View Post
    That's probably the most significant thing about successfully lifting a front wheel without triggering the Nanny - if you can keep off the brakes as you work your weight, the steering, & the throttle to keep all the other forces balanced without exceeding the sensor limits (especially the Yaw sensor - there's a smidge of leeway with rear wheel spin, even on an RT! ) it's possible to ryde safely for quite some distance with one front wheel in the air. It's generally easier if you start with a gentle turn & then add in a bit of a blat of harder steering than is strictly necessary to get the wheel up, then it's a balancing act for steering & body movement teamed with some gentle throttle corrections so you can hold the 'Spyder Salute' for a fair way!
    But for most ryders, you really don't need to worry too much about lifting a wheel, the Nanny will step in PDQ if she thinks you're gonna go over! . Sure, she can't protect you from the really aggressive wheel lifts that massive evasive action or downright silly/stupid control inputs can bring, but short of those &/or being tagged by something like a kerb or another vehicle, the Nanny is generally more than capable of looking after you!
    So, don't be too 'scared' of things like gently lifting a wheel happening, or even of doing something that gets a gentle admonition from the Nanny - it's all stuff you can learn from! . Just work out exactly what it was that you did to produce whatever the particular disturbing event was, and then either learn to keep your ryding inputs juuuust below that limit, or if you're more like some here (opps you might wanta learn how far you can (hopefully gently & progressively ) push that envelope without getting smacked down hard by the Nanny!! . (Or if you're really into pain, you can push it 'til you get slam dunked onto the tarmac! I'm not sayin' nuthin' more 'bout that, except that IT HURTS! . Nanny usually looks after the Spyder tho! )
    In the meantime, just........
    RIDE MORE, WORRY LESS!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2022
    PA
    Sounds the same as my (our) experience. I just instinctively backed of the throttle immediately and it came back down. There was no interference from the nanny. Apparently because it was quick, no brake, and no significant slowing of the lifted wheel. But I was looking at the dash and wondering if I was going to have my wrist slapped by the nanny.
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    I have actually been able to pull a short wheelie with both wheels at one of our lights near work . It's a left turn with a slight incline from the light.
    I have had a couple people from work see me do it and they tell me they didn't know I could do a wheelie with it.
    I didn't know I could do it either nor realized I was doing it because it was such a smooth transition that was happening with the road.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Active Member FIRECAT's Avatar
    Aug 2010
    WINDSOR,ONT,CAN
    Yes, it happened to me too. Lots of fun. I can do it on
    Command now.
    SNOWMOBILING ON PAVEMENT!!!
    Dec 2018
    Elanora, Qld, Australia
    I'm having ever so much trouble getting both fronts off at the same time. Rear read is not lasting long at all.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    You guys will enjoy doing that till you snap one of the plastic swaybar links.
    T.P.
    Quote Originally Posted by JohnRuckus View Post
    Nice catch
    Now I am a bit curious too.
    Oct 2016
    Faribault, MN
    So I take you all haven't seen the 6 year old video of the guy test driving one of the Police model Spyders, pulls out of the parking lot in a Spyder salute wheelie. Youtube at https://www.youtube.com/watch?v=zElfDrZzvl8
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2020
    Lake Sam Rayburn Texas
    When turning left, the centrifugal force is to the right which could cause the left wheel to lift.
    Oct 2014
    Vancouver Island anada
    I've had that happen on a quick right hander, the missus asked the inevitable and yes it did!
    2012 RT , Yes Lava Bronze
    Mar 2022
    PA
    Now that I know it can happen, I don't really have any intention to do pop up a wheel again, certainly not on purpose. Perhaps if it happens during an evasive maneuver, I will expect it and lean more in preparation?
    It's like when I was a teenage driver, many years ago, we would take our cars onto an icy parking lot and spin it around for fun. But I can honestly say that having developed that ice-handling skill saved me from a crash more than once. (For you southerners, yes the roads up north will freeze up from freezing rain or packed snow. )
