Spyder pulling to left - Any ideas/suggestions?
Can't solve my Spyder issue it pulls to the left while driving. Tire pressures are equal at 16 lbs. , 3 oz. balancing beads are in place. I tried rotating the front tires and it made the Spyder pull to the opposite side. Any ideas/suggestions?
Reason: Expanded Title to briefly ask the question ;-)
If the pull goes with the tire location, it is a tire problem. Possible broken ply in the tire. Replace tires.
Bump up the pressure a few pounds and see if it’s any better.
As mentioned maybe bad tires.
Exactly. Your problem follows the tire, it's a problem with the tire.
Replace the tires with a car tire.
As always, my free advice comes with a double your money back guarantee.
IBA #47122
2020 RT Limited Asphalt Grey
As stated by SpyderJerry, it is a problem with the belts/casing in the tire... Happens even with car tires. I have a Michelin causing a drift on my McLaren right now!
Chuck
More tire info would be helpful ..... however as others have said if the issues Follow the tire ..... then it's probably the Tire .... JMHO .... good luck .... Mike
