Results 1 to 4 of 4
    Aug 2022
    PA
    Default Fitting '19 Max Mount to '22 Ryker - what am I missing?
    I purchased a max mount that was on a 2019 Ryker Rally for my 2022 900 ACE. I looked up the part numbers and they matched, so I thought there would be no issue. I tried to mount it today and the bolt holes are about 1/4" off. I couldn't see anything preventing it from sliding the entire way in. The max mount does have scratches and nicks, but it didn't seem bent at all. Am I missing something or am I not seeing where it could be bent?
    Any thoughts would be appreciative.
    Last edited by Peter Aawen; 08-27-2022 at 06:08 PM. Reason: Expanded Title to briefly ask the question & fixed attach display;-)
    Dec 2013
    I don't think you're missing anything..... except for you to realise that BRP's quality standards aren't quite as high as might be expected, especially on the Rykers....
    Sorry
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member DickB's Avatar
    Jun 2021
    FL
    Can you bolt it one one side and not the other?
    Active Member EchoVictor's Avatar
    Aug 2021
    Milford, MI
    When I installed my Passenger Seat footpegs on my '22 Sport, I had issue fitting the spacer on one side into the appropriate gap on the max mount. So, the casting doesn't seem to be that dimensionally stable. I'm with Peter.... seems to be not the best QC on this part.
    Later,
    EV
    2022 Ryker Sport, 2006 Buell Ulysses XB12X, 2007 Buell Firebolt XB9R, 2023 KTM 390 Duke
