Do Rykers & Spyders use the same battery?
Do the Ryker and Spyder F series use the same battery?
Thanks.
Reason: Expanded Title to briefly ask the question %-)
Ozzie Ozzie Ozzie
I must admit that I don't have a Ryker handy to check atm, but I believe that all the Can-Am 'Reverse Trykes' use the same batteries as all the Spyder models, be they a GS, RS, RSS, ST, RT, or an F3 or any of the variants of those models.
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Just looked it up on Slingmods and Yuasa site. The Ryker uses a 16-HL and the Spyder uses a 24HL.
Hope that helps
John
I have both a '21 RT and a '20 Ryker Rally. The battery in my RT is much bigger. So in my case, no, they aren't interchangeable.
2021 RT Base - Petrol Blue
