Results 1 to 3 of 3
    Member CanAmFam's Avatar
    Aug 2016
    Westside Indianapolis
    Default 2021 RT LTD Glove Box will no longer latch - any ideas?
    Glove box will no longer latch while ryding.
    It will lock when turning handle bars to lock if I hold down the glove box lid?
    Last edited by Peter Aawen; 08-21-2022 at 08:43 PM. Reason: Expanded Title to briefly ask the question ;-)
    2021 RTL Chalk 2021 F3T White
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    I can't find anything in the service manual about adjusting the latch, but there appears to be an adjustment on the cable that pulls the latch to the locked position when the handlebars are turned. Wish I could be of more help. Here's the drawing I'm referring to:
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Dec 2020
    Hartwell, Ga
    With all the problems that the saddle bag cables on the newer models are having, I would check that cable to make sure that it is not sticking. Maybe try some dry lube on the latch itself. Make sure that if you do that it's safe for plastic.
