Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    Good theory, but surely if that was the case, they wouldn’t have included the ability to simply downshift to turn off the CC and slow without showing brake lights, Idaho ?
    Up shift also turns off CC.
  2. #27
    Jul 2022
    ny
    Not if you're in 6th gear .
    Last edited by Peter Aawen; 08-24-2022 at 07:25 PM. Reason: your (implies subject belongs to you) - you're (contraction of you are) %-)
  3. #28
    Oct 2021
    Wichita, KS
    Quote Originally Posted by ron1026 View Post
    Then you can't upshift. Upshift does cancel cruise control. Idaho is absolutely right. What you are implying is that downshifting from first gear does not cancel cruise control either. You can't downshift from first gear so same situation.
    Peter Pan has struck again!
  4. #29
    Harrington, Australia
    Gee……we are really making a mountain out of a molehill here. Most unlike Spyderlovers Most people are running in 6th on a freeway. That is the reason I only said “downshift” as there is no upshift possible. Of course CC will cancel if you downshift OR upshift if that option is available to you
    Besides that, my comment was in relation to Idaho saying that BRP wanted you to use your brakes to show the vehicle behind that you were braking. I was simply pointing out the flaw in that argument, but it has now been taken down a different, effectively unrelated, rat hole
    HeliBars Handlebars
    Kenda Kanine rear.
  5. #30
    Jul 2022
    ny
    Quote Originally Posted by FrogmanDave View Post
    Yes you are right you can't upshift if in 6th gear. But my goldwing if you were in top gear ( 7 ) and hit the upshift button it would disengage cruise control.
  6. #31
    SoFlo
    Would have been very nice if BRP had incorporated a setup where when cruise control is engaged in sixth gear at upper highway speeds, selecting the paddle in the upshift direction would disengage the cruise control.
    Certainly no plans to accomplish a 6>5 downshift at 80 mph, and tapping the brakes at that speed is a bit odd too, but what is required. With the fragility of many of the Spyder controls, I too leave the cruise control always on.
    Years ago, I sorted out the electrics to utilize a cruise control disengage system. Just never took the time to wire it up. Maybe it is time to revisit this and make it happen.
  7. #32
    Jun 2021
    62431 Illinois
    Bingo,works for me
  8. #33
    Quote Originally Posted by Crackerjack99 View Post
    Bingo,works for me
    ???????????? What post are you replying too?
  9. #34
    Jan 2019
    Hunter Valley NSW Australia
    I tap on the brake. It trips the Cruise control and sort of warns the guy behind me I'm dropping speed.
    Sometimes I'll drop a gear due to a need to drop a gear knowing it will trip the CC
    2017 RTL
    2017 RTL , White
