I added a Pedal Box to my 2012
I purchased a Pedal Box from Martin the Vlogger for my 2012 RT. When I have my wife riding as a passenger the 998 always seemed a little sluggish from a stop. The Pedal Box certainly corrected that problem. I have it in city mode most of the time. Sport mode is just unbelievably responsive. I would recommend it to anyone. Not to mention the install is very simple.
2012 RT , Replaced with Bahrain wires Red
Lamonster only has them for the 2014 and newer models.
Ah Ha, btw, what are Bahrain wires Red (in your Signature)?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Do you have any pics of the install. I have a '12 RTL also, but can't find what I'm suppose to find.
I just bought a 2020 Spyder RT Limited. Seems more than likely I will buy a Pedal Commander as well, in spring. I watched a you tube video where the guy went through the settings and timed the response in each setting. It really sped up that 1330cc! In the highest Sport+ setting, it gained almost 2 seconds for 0-60mph. Impressive, to say the least. I hope no one cares if I also ask about XM Radio? I never really listen to FM, just XM. My Honda GW was very easy to upgrade, just add an XM Radio antenna, and have XM active on the radio. Is it the same for my Can Am?
EODSF, you probably should ask that XM Radio question in a new thread versus appending it to a Pedal Box/Commander thread.
Safe Rides,
IBA 70020 |
