Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Sep 2014
    USA
    Quote Originally Posted by fetermel View Post
    Not true, at least in my case. My wife and I went for a ride last Sunday [both have 2013 STS] both started right up in the garage, stopped and put gas on, started fine again. About an hour ride to our destination and when we going to leave hers was completely dead. I tried my jump pack, wouldn't even turn it over. Long story short, I ended up taking my month old battery out of my spyder and putting in hers to start it and then I took it out and reinstalled the dead one, While it was running. Wasn't sure if this was going to work but it did, ran just fine until we got back home. Put my load tester on it when we got home and as soon I hit the load button it killed the motor instantly. Putting in a new one Today.
    Yes it is true. Anyway done with this topic carry on.
  2. #27
    Idaho
    Ok. Now try it on a Spyder with the battery that is bad. We are not comparing it to a generator right now. If the battery on a Spyder goes bad it will not run or start. Jump pack may turn it over but will not get you home.
    OK, my goof. I read your comment as being a blanket statement and didn't think about the fact that since this discussion is in a Spyder forum you were focusing your comment solely on Spyders. I have no experience starting, or trying to start, a Spyder with a totally dead battery, and figured a Spyder would respond the same as other equipment. My experience is all non-Spyder related.
    2014 Copper RTS
  3. #28
    Active Member RULINGCHAOS's Avatar
    Oct 2022
    Sikeston, Missouri
    I probably need a new battery. Any recommendations? Also I never thought about a small battery pack to travel with. Any recommendations there also?
    2017 Spyder RTL
    Mods
    Baja Ron Swaybar
    Mesh Intake covers
    LED Skidplate
    LED Headlights and Foglights
    TricLED Dual Color LED A-Arm Running Light Strips with Blinker
    12V Cell Phone / GPS Docking Station with Dual USB Charge Ports
    Quick detatch backrest
    Show Chrome RT Trunk Rack
    Show Chrome Short Spiral Radio Antenna
    Custom Airbrushed paint with ghost flames
  4. #29
    Jun 2021
    Dunsford Ontario
    I don't agree. We have a generator at the home farm that has a deader than door nail battery which we use a jump start battery to start. Works just fine. Also, the Yuasa battery in my ATV decided to take a dump. After an hour charge at 10 amps it was still totally 100% dead, but started just fine while the charger was connected.
    Yup.battery on my Jenny is always dead come spring when I get home in the spring.I put the old tender on it maybe couple hrs and it starts right up.
    2019 F3 Limited Pearl White
  5. #30
    Idaho
    Quote Originally Posted by RULINGCHAOS View Post
    I see you are fairly new to the forum. When you, or anyone, has a question of this sort please do a search on the forum before asking for recommendations. Why? This forum is is on the order of 15 years old and Spyders have been using the same battery since day one. Therefore this exact issue has been discussed dozens, if not hundreds, of times through the years with many different recommendations being made. There is no firm consensus on what replacement battery is the best. One consensus among many users is that for overall value the OEM battery is a very good choice. But you must charge it correctly before putting it into use.
    By doing a search you will discover many more options than you are likely to receive in response to new post. Good, bad, or indifferent, the fact is forum members do get tired of answering the same question time and again.
    If you do not find the info you are seeking after doing a search, then make a post and say so. You'll get good answers.
    Also, be sure to check the date of the last post in a thread. Many times it's better to make a new thread which will catch more attention than a post tagged onto a dormant thread that was last used maybe years ago.
    2014 Copper RTS
  6. #31
    Sep 2017
    INDIANA, USA
    Default Need a New Battery? ? ?
    ...Well, if you don't want to get stuck on the road and then wait for 3 or 4 hours for some help.
    A little Tip on the battery...... How old is your battery?
    Four or more years?
    I would change it out with a New Battery.
    Battery 1 to 3 years old.
    Are you able to load test a battery or can get someone to do it for you?
    If you just replaced your battery, less than One year, get it checked out from your battery supplier.
    Any questions just ask.
    Battery life is all about the way it is treated.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
  7. #32
    Dec 2015
    Oakley Utah
    Spring.
    2014 RTL Platinum
  8. #33
    Sep 2017
    INDIANA, USA
    Default Depends On Season Where You Live
    Your Spyder ryding season will be your best help. I am good to Go when temperatures are 50'F or higher.
    Soooooooo.......if your Spyder Ryding Season is only April to October.
    But if like my Spyder Ryding Season of All Year Around then GO For It Today.
    You NEED A Good Battery All the Time.
    Good Luck on Your Mission. ........
