Anyone using these OEM Oil drain plugs with hex head?
Have read here that some aftermarket hex head replacement oil drain plugs have broken off. Some say it’s because the thread wall is not thick enough because of the magnet. Some say it’s due to over tightening. Saw this OEM one below on a Google search. Comparing pictures of the Show Chrome and this one, it seems the magnet is thicker in the Show Chrome. Anyone using this OEM plug?
https://leadersrpmshop.com/can-am-ne...yABEgLAVvD_BwE
Edited this post because the above link doesn’t come up anymore???
Reason: Expanded Title to briefly ask the question ;-)
When these re-placement plugs appeared on the market There seemed to be more Failures with the DIMPLE Brand ( I don't think they are made now ) ..... and the failures were due to a too thin thread wall or overtightening which damaged the Alloy Pan ... I don't recall the HEX insert plug being an issue just the engine bolt type ..... JMHO .... Mike
I just order one for stock...Will compare it to what ever brand hex plug I have at my next oil change over the winter...THANK YOU for the link...larryd
Lamonster has these on his website, think they are called 'gold plugs', set matches exactly what you need, reasonably priced as I recall. For me, the OEM plugs were a real pain.
I posted because this is an OEM part. It is available from the dealer. Upon doing a search it fits all 3 cylinder from 2014 to 2022. Here is a link. Was curious if this part just became available or was out there for a while.
https://www.canampartshouse.com/oemp...arch=420441681
Less than $20 for both Gold Plugs vs. $41 for a single. Gold plugs have a good rep.
I been using the Gold plugs since the first oil change @ 600 miles. Never had a problem. Over tightening is the main cause of stripped threads or broken plugs.
Used hex head magnetic plugs in the primary drain of Harley Sportster for 350,000 miles before I bought the Spyder. Never a problem with it either.
"404 Error - Page Not Found"
I bought these Magnetic Drain Plugs from www.lamonstergarage.com
They work great so far. I believe the trick is NOT to use "gorilla torque".
Plus, Lamont seems like a standup guy and wouldn't sell any jenky merchandise he doesn't believe in.
Reason: Link
SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2018 Can-Am Spyder RT Limited - hers
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - the dog's
1995 Fleetwood Flair 27R - EVERYBODY'S !
That is the trick. I don't torque at all. I use a fiber sandwich washer and just snug it up with a shorty 3/8 ratchet.
Brand new washer every time.
Ozzie Ozzie Ozzie
Hmm, link worked fine for me - still does?!?
