Another belt tension question
I have done quite a bit of searching for belt tension specs. for my 2014 RTL. The latest TSB
I found was dated 2015, stating the tension should be 630n +-100 with rear wheel off the ground. Does anyone know if more recent guidance has been published?
Thanks
Thanks
Not from BRP, as far as I've heard ..... do you have a SONIC meter ???? .... if not buy a Gates KriKit II from Ron ..... my 14 RT is at 160lbs with wheel on the ground and I love it ..... Mike
+1 on the 160lbs rydes great with very little belt vibration noticed
2017 RTL Asphalt Grey Metallic Chrome
I do have a KriKit II from Ron. My tension is 220 with the rear wheel raised. Lifted from the back part of the frame just ahead of the cat/muffler. I guess that is WAY too tight!
Thanks for the info! Always appreciated!
Someone may clarify this , but my understanding is that 160 on the ground is equal to 180 off the ground...... I don't go to the trouble of jacking the Spyder up because I use 160 .... if I raised it, it would read 180..... I'm old and a bit lazy so I don't bother ..... JMHO .... Mike
I thought raising off ground till shock limits, would have a lower tension reading. Lowering back to ground would make tension a little higher reading. No reason to raise, don't have to spin tire to check or adjust tension
I just check it on the deck. Careful if the motor is running as the pipe is not that far away. I placed a spare finger on it. Yeha! My Krikit lives in the LHS saddle bag.
That is why you can raise it up and walk the belt off and not have to mess with the adjusters.
I know and understand this, but only talking tension here, not tire replace or adjust
Thanks
If you are fighting vibrations, a smooth spider belt tensioner will absolutely get rid of them.
I have been happy with 200 off the ground, when I lowered it to 160 I was getting a lot of belt vibration in a wide range of speed between 45-55 MPH instead of 75-80.
At 200 I still get some vibration but it is in a smaller range at 62-65 so I just avoid those speeds.
I thought about a belt tensioner but I would rather live with the vibration or just avoid that speed.
I choose to minimize the risk of drivetrain failure rather than adding in a belt tensioner as that is adding in an additional part that needs maintenance or that can fail and damage the belt while underway.
2020 F3 SE6
Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
Tackform Center Mount Phone Holder w/ rapid charging USB-C.
Sorry bout that Wood, just adding a real world example for others to your comment.
