Results 1 to 14 of 14
    Nov 2016
    Colorado Springs
    Default Out on a ride and lost power between engine and the belt
    We're riding through Ouray Colorado when the spider suddenly lost drive power and started making a rapid thumping noise. We got it trailored back to our hotel. Mechanic thinks it could be the recall.
    https://youtu.be/hMD8BS6gORM
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Did you had the interim check done by the dealer, there is an interim solution, where they measure the width between the teeth of the sprocket, so they could tell if there's premature wear....
    it's part of the recall, mine is measured, all within spec, nothing to worrie about, till proper solution comes
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Durham,Maine
    was the bike in gear when you made that video?
    2012 RTL , Pearl
    Nov 2016
    Colorado Springs
    Yes, bike in gear.
    Nov 2016
    Colorado Springs
    Default Does this video match the 2015 to 2019 sprocket recall?
    I was pulling onto the highway when the spider lost power and made an ugly sound. I makes noise every time I tried to throttle up in gear. There was just a tiny bit of drive power if I throttled up very slowly, but then it would start buzzing again. The mechanic isn't sure if it's the recall or not and can't get me in for nearly a month. He said they don't have parts to fix it yet anyway.
    Jun 2011
    Alamogordo, NM
    How many miles and what year is your Spyder??????????
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    I'd say there is about a 100% chance your front drive pulley spun on the output shaft. Which means you have a better than 80% chance the output shaft is also toast. BRP definitely needs to up their game on this.
    25K+ is going to be a hard sell if you can't trust the drive train. And I'm sorry. No excuses. Owners have been spinning drive pulley's since 2008.
    Active Member SpyderF3-s's Avatar
    Oct 2015
    Menifee, CA
    100% guarantee it is the sprocket! I've heard that sound several time!! Most likely you have over 15,000. You can't order a replacement sprocket from BRP ( I tried so I could have a spare). Local dealer can't get the part either. He suggested to wait to see what the permanent fix is.
    There is a guy on the forum from Canada that has a sprocket for sale (old part number) but it would get you running again. Or look on Ebay.
    It is any easy change that takes less than an hour ( I've had to do this three times).
    God bless those who serve/served our country!
    Nov 2016
    Colorado Springs
    2019 RT Limited. 18k miles
    Vin is on the recall
    May 2020
    That is only going to work if his output shaft isn't damaged, that would be a whole different story. Take off the tupperware and inspect the sprocket yourself, it is easy to see; if you lift the rear wheel of the ground and turn it, look to see if the sprocket and output shaft are moving together - if there is slack between the two, then you are in for a costly repair...
    Do not let the engine run in gear any more before you check, cause you could easily damage more...
    I'll keep my fingers crossed that it's only the sprocket, but hearing the sound on your video, I am with Dave on this one
    Swaybar (Ron's)
    Dec 2015
    Oakley Utah
    You keep saying you 'lost power', implying the engine lost power or went into limp mode. Is it more accurate to say the Spyder's drive train failed in some way because it seems the engine is producing power okay.
    Just wondering. I'm kinda anal / literal.
    2014 RTL Platinum
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    That's how I took it. I believe the engine was still making power, but there was little or no forward propulsion.
    Which leads me to believe that the sprocket is toast ........ which can be a good thing since it's an easier fix than some serious engine issues.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Nov 2016
    Colorado Springs
    Maybe instead of a spacely sprocket I should get me a cogswell cog
    Oct 2021
    Wichita, KS
    Quote Originally Posted by ClayJ View Post
    I don't care who you are. That's some funny s**t there!
    Peter Pan has struck again!
