2013 RT Ltd not starting - any ideas?
I have dash flicking on several times. Battery is fully charged, cleaned all connections
Turned key on and dash is flashing, parking lights doing same. Does this several times then nothing.
Temp. gauge needle jumping and then everything stops.
Any ideas on what could be wrong.
Thanks in advance for any help
Check to make sure your grounds are CLEAN and tight, Both ends!!!
Ozzie Ozzie Ozzie
2013 not starting
take your battery to Battery + and have it load tested, I'd say you need a new battery.
Al in Kazoo
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Peter is spot on (he usually is), me thinks there a bad cell in the battery, fully charged, does not mean fully functional...in this case, I saw in your signature a 2013 rtl, is it still the original battery?
That would make you a very lucky guy, even with proper maintenance, a battery, can go bad overnight...
the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
Spyder F3s 2019 All Black ( Named it: Brutus)
Carbon Items added, just for looks
Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
Swaybar (Ron's)
Tyres Front Michelin Cross Climate+ 175/60-15
Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
Exhaust Bone stock, with a RLS Cat- Delete
Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
Pedalbox, Awesome Upgrade...
+1 load test, FYI possibly also lost trip meters with dash flicker.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Thanks for all the info. All connections were cleaned and tightened and battery is 2 yrs, old with tender used.
Will have it load tested. Will let you know what I find.
Ozzie Ozzie Ozzie
Yeah, 2 y/old shouldn't be bad, but even brand new batteries can fail; and also, using a tender all the time/too much can be a bit of a trap and actually shorten the battery's life rather than prolong it.
It's best to just never put your Spyder away without a fully charged battery &/or after a good run of at least 30 mins ast Hwy Speeds, longer if you were only tooling around at lower revs; and then unless you're going to leave it sit for more than just a few weeks, don't put it on a tender!
Keep the tender for those prolonged periods of no running, and even then, unless it's a 'smart tender/battery maintainer' that has a discharge/de-sulphate/float period or cycle built in, it's probably best to take it off the tender for at least 1 week out of every 4.... or therebouts!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
It was the battery and come to find out it was 4 years old. I will take the advice about tender use.
