Will a 225/60R15 General RT43 tire work on an F3S?
do the 225x60x15 general rt43 tire work on the rear for f3s can am spyder?
richie spyder
Hello. Same question here. I'm looking at The BFGoodrich Radial T/A All-Season P225/60R15. I ordered a Kanine in March and they keep on pushing the shipping date later and later. September now and I don't believe them. Thanks.
Since the OE size is a 50 series vs 60 that you mentioned, it is quite a bit taller than stock and most likely will cause probs with the onboard systems... It may rub under 2 up, heavy loading or heavy compression of the rear suspension due to road conditions....
Chuck
Originally Posted by rjinaz86323
I run a 225/60 on my 18 F3L with zero issues. Usually 2 up and neither of us is small
225 or 215? Tons of folks use the 215/60 but you'd be the first I can recall with a 225/60... If so, congrats on no problems. No issues with the "nanny" either? Also, I'm not sure the S and L run at the same ride-height, plus you have air suspension and auto leveling, S doesn't...
Chuck
Definitely 225/60
Folks here have already tried every tire size combination possible and none have caused computer issues. The size variance is very limited as is tire availability ..... JMHO .... Mike
