Are there any 1-up seats for the RT-S
Looking to be able to change riding position now and then. Will not be taking a passenger.
Thanks
Ozzie Ozzie Ozzie
As an old fart who's about 6'3" with a BRP Comfort Seat on my Spyder, I can't imagine what advantage a "solo" seat would do for me. If you look at the Spyder from either side it is intuitively obvious that the seat profile going rearward from the lumbar support of the Comfort Seat would reduce the thickness of the seat, wipe out the very comfortable and adjustable driver backrest, would increase the distance from my shoulders to the grips of the Tri-Axis bars, thereby necessitating a mid-ride stop to readjust the bars. All in all it would be a fruitless attempt to spit shine a t**d, which we all know can't be done. If one had a custom made seat that did not have reduced thickness as the rider moved rearward, all it would do is move the dude higher on his perch with all of the aforementioned problems. Highway pegs would be a cheaper, more successful solution.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I see your point. The highway pegs I have looked at (pictures) so far, it seems they just spread your legs out more, without an appreciable length gain. Of course, there may be some out there yet. Right now I sit on the backrest for awhile to ease the pain.
2016 RT-S SE6 White
5000 miles
Ozzie Ozzie Ozzie
2016 RT-S SE6 White
5000 miles
I do not like highway pegs for just the reason you mentioned. I learned to grip the tank with my knees when I first learned to ride and especially racing. I still grab the seat with my knees, particularly in the twisties.
Cognac 2014 RT-S
Floating highway pegs (boards)
You can look at the "floating highway pegs " that CanAmSpyderAccessories.com has. I have a set on my 17 RTL and they allow you to stretch out your legs without spreading your legs apart farther. They set in front of the foot boards and on top of the black splash guards. Could be what you are looking for.
https://www.canamspyderaccessories.c...y=Highway+pegs
Reason: Add link
2017 RTL Asphalt Grey Metallic Chrome
Yes, that looks like more what I had in mind. Thanks!
2016 RT-S SE6 White
5000 miles
Looking forward to seeing what you come up with
For now, I decided to just sit on the backrest for awhile to stretch my legs.
2016 RT-S SE6 White
5000 miles
Well possibly you could adapt a newer RT seat ( which is a two piece type ) to your frame ( which is the same ).... but it's not going to be cheap .... good luck .... Mike
