Results 1 to 11 of 11
    Jun 2015
    Ritzville, Wa
    Default What type of Charging cable for Sena headset?
    Does anyone know what type of charging cable the Sena headset uses? I know it had a stanard USB connection on the end that plugs into the computer, but what is the end that plugs into the Sena called? Is that a micro USB?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Aug 2019
    Stoughton, WI
    My 5S uses USB C, while my 10C Evo uses Micro USB. What model you have?
    2022 RT Sea To Sky
    Jun 2015
    Ritzville, Wa
    The manual cover says SMH5. In the box contents section, it just lists it as a USB charging cable, but t doesn't say if the end that connects to the device is a micro USB or not. I know by looking at it that it's not a A or C so I'm guessing it's a micro or micro mini.
    Greg Kamer
    Dec 2015
    Oakley Utah
    This is a Micro B
    2014 RTL Platinum
    Jun 2015
    Ritzville, Wa
    OK, I figure out it is a USB-C cable. Which I have a few of, so it's all good. Thanks for all the input.
    Greg Kamer
    Dec 2015
    Oakley Utah
    Quote Originally Posted by gkamer View Post
    So, it's not the same as in the picture then?
    2014 RTL Platinum
    Oct 2015
    Lynden, WA
    I use a Micro B on my Sena 10.
    The Sena uses the same cable as my Samsung J7 Cell phone.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Dec 2015
    Oakley Utah
    Do let us know how that works out for you. We might all learn something.. Thanks
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    How is that again? You knew it's not a C type and now you know it is?
    I'm pretty sure it's a Micro B. Look at the picture I posted and tell us if that's what yours looks like or not.
    2014 RTL Platinum
    Jun 2015
    Ritzville, Wa
    No. I looked at the cable that came with the Sena and it looked like a USB-C. So I stuck a USB-C cable that I had into the Sena and it chripped and displayed the charging icon so that made me guess it was actually a USB-C.
    This is the cable that came with my Sena
    The top cable is the one that came with my Sena. The bottom is one of the USB-C cables that I had. Both work to charge the headset.
    Greg Kamer
    Dec 2015
    Oakley Utah
    Thank you. Yes, that's the micro C.
    2014 RTL Platinum
