Results 1 to 17 of 17
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Default Brake fluid compatibility - can I mix OEM with Prestone DOT 4 synthetic?
    I am ready to change the brake fluid on my 17 RTL and I need to
    know if I can flush out the original brake fluid OEM with Prestone
    Dot 4 synthetic brake fluid. I don’t know if it is okay to mix these two
    in the brake system. Any help and information would be greatly
    appreciated. TIA
    Artie
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Nov 2015
    Chardon, OH
    Artie…DOT 4 is DOT 4 is DOT 4. ALL brake fluid is “synthetic”. Yes, brake fluid is hydraulic fluid, but brake fluid is glycol based and not mineral oil based. The brake fluid in your machine is glycol based DOT 4. Prestone added that word “synthetic” years ago for marketing. What you can’t do, is mix DOT 4 with DOT 5. DOT 5 is silicon based. Use the Prestone DOT 4. No problems.
    Doug
    ”Freedom is not a loophole”
    Jul 2020
    Sikeston ,Missouri
    Thank you Snowbelt Spyder, that is what I needed to know. I just didn’t want to cause a major problem
    with the braking system. The nearest dealer to me is a 2 hr trip. Now I can do the brake fluid change with confidence. You have saved the day! 😃
    Nov 2015
    Chardon, OH
    You are definitely not the first to wonder about this. Hoping that you will be using Speed Bleeders. Makes this job just too easy. Even a cave man could do if. Also, DO NOT have the ignition on while doing this. That will trigger that stupid brake failure error, that has to be reset using that series of steps I’m sure you’ve read about on here. Only turn on the key until you’re all done, fluid topped off, and pedal pumped up.
    Doug
    Jul 2020
    Sikeston ,Missouri
    Yes I have bought the Speedbleeders for the front and back ,yet to be installed.
    Thanks also for tips on doing the job correctly. I have done my research on changing
    the brake fluid but could not find anything about the compatibility of the OEM fluid
    with the Dot 4 synthetic I bought. Maybe this thread will help someone else in the
    future. That is what this forum is all about helping each other when you can.
    What he said...
    You can also use DOT 3 in a pinch. But DOT 4 is better and should always be used, unless you just can't.
    Mar 2013
    Just did both my wife's 2021 RT and my 2020 RT.
    What I use was https://www.harborfreight.com/brake-...der-92924.html.
    Interesting that the 2021 oem fluid was the same color as the 2020. Looked like coffee.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jul 2020
    Sikeston ,Missouri
    Thanks again every one that posted a reply to my OP. I was able to get the Speedbleeders installed and the brake fluid flushed without any problems.
    I made sure to not turn on the key until I had everything back together and brake reservoir filled and closed and then pumped the brakes several times.
    We took the Spyder for a ryde about 80 miles total and never had the brake light or warning come on. All is good!
    INDIANA, USA
    Default Speed Bleeders
    Quote Originally Posted by Partzman23 View Post
    Any chance of getting the part numbers for the Speed Bleeders?
    Where did you purchased your 'Speed Bleeders'?
    TIA .........
    ENJOY YOUR LIFE WITH A SPYDER
    Clinton, MS
    Quote Originally Posted by Little Blue View Post
    TIA .........
    Here's the part listing on their website Blue. http://speedbleeder.com/bikechart.htm
    Sep 2020
    Middletown, NJ
    I've been told that DOT 5.1 Brake Fluid is also compatible with DOT 4. Is that correct?
    2020 RT base , Chalk White
    Mar 2013
    Quote Originally Posted by RayBJ View Post
    Since DOT 4 and 5.1 are both glycol-based brake fluids they are compatible with each other, which means they can be readily mixed without harming your brake system. It is important never to mistake DOT 5.1 (glycol-based) with DOT 5 which is silicone-based and should never be mixed with any other DOT fluid
    Oct 2021
    Wichita, KS
    Quote Originally Posted by PW2013STL View Post
    I've got that Harbor Freight tool as well. This works better and is way easier than all the rest https://www.motionpro.com/product/08-0143
    I am curious to know why brake fluid looks like coffee when new?
    Peter Pan has struck again!
    Mar 2013
    Quote Originally Posted by FrogmanDave View Post
    It doesn't when new. It turns that color with contamination. I was surprised that my 2 year old fluid was the same color as the 1 year old. I was expecting it to be darker. When I did our 2014 RT after 3 years it was black.
    Oct 2021
    Wichita, KS
    My bad. I misunderstood what you were saying. I thought you meant the new fluid was dark to start with. I'm tracking with you now.
    Jul 2020
    Sikeston ,Missouri
    TIA .........
    Part number SB6100 for the front and rear, bought from Speedbleeders.com website, also ordered the tubing from them to drain fluid into jar
    Mar 2013
    I like the harbor freight one as it doesn't require the brake pedal to be depressed while bleeding.
