Results 1 to 23 of 23
    Jul 2018
    Germany
    Post Searching for LEDs for Tail/Brake lights - any ideas?
    Hello,
    I am searching LED-Bulbs for the Tail and Brake light.
    Do you have any proposals for me..??
    I had read that it is not possible to change to any kind of LED bulb, as maybe the Spyder wont start??
    Greetings from Germany
    Last edited by Peter Aawen; 07-31-2022 at 11:26 AM. Reason: Expanded Title to briefly ask question - I think?? Fixed for tail/brake. ;-)
    2014 STS SE5 , circuit yellow (metallic)
    Dec 2013
    Hi germanspyderrider, I can tell about the Brake lights, but I'm not exactly sure which other lights you want to change to LED's?? Do you mean the Reversing lights (back up? - you EU fella's & us Ozzies have something completely different to everyone else back there! ) or just the tail light that lets everyone know where the back end of the Spyder is??
    There are LED's available with built in resistors so that you can use them in vehicles that are particularly voltage sensitive like our Spyders, hopefully someone will have an answer/source or part numbers for you - once we know exactly which lights you want to replace?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2018
    Germany
    Hello,
    i mean the tail light - the brake light is the same bulb
    Dec 2013
    Quote Originally Posted by germanspyderrider View Post
    Hello,
    Fixed - now I hope someone can help?!
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I order 2 of these from Amazon for $22
    BAU15S LED Bulbs Amber Yellow 2800LM Turn Signal Built-in Load Resistors
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Jul 2018
    Germany
    Quote Originally Posted by rjinaz86323 View Post
    Sorry - i need those with twin filament light bulb for tail and brakelight
    But anyway thank you for help
    Mar 2021
    I am not sure what you saying. These work for both tail light and brake light.
    Sorry - i need those with twin filament light bulb or tail and brakelight
    Jul 2018
    Germany
    Ok - we have other rules about lightning in Germany.
    You wrote a link for bulbs in amber - ours must be red..
    Did you understand me now?
    Last edited by Peter Aawen; 07-31-2022 at 11:01 AM. Reason: anderstand - understand ;-)
    Mar 2021
    Sorry, brainfart on my end.
    Dec 2015
    Oakley Utah
    He's looking for an LED equivalent to a dual filament bulb used in combination brake/running lights, I think.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Hello,
    I am searching LED-Bulbs for Back/Reverse(?) and Brake light.
    What is the OEM incandescent bulb and base number?
    2014 RTL Platinum
    Jul 2018
    Germany
    I can´t find the OEM
    The specification (without LED) as analog bulb is 12V 21W/5W BAY15D
    Dec 2015
    Oakley Utah
    https://www.google.com/search?q=LED+...e-gws-wiz-serp
    https://www.amazon.com/HQRP-BAY15d-S...05002399&psc=1
    Is this any help?
    2014 RTL Platinum
    Jul 2018
    Germany
    Hello Pete,
    many thanks, but it is only half help.
    Our Spyders need bulbs (especially the brake light bulbs) that are canbus compatible.
    If we use the normal LED bulbs the Spyder will throw a code that causes it to run in Limp Home mode, because the canbus is thinking there's a broken brake light.
    Hello Pete,
    Maybe I can simplify this ...... All Spyders have bulb MODEL / TYPE numbers assigned to them ..... Like H-3 or 9005 ( theses are for headlights ) .... take the bulb out and use the number printed on the bulb to find it's LED equivalent ..... Make sure the LED's are Can-bus ready ..... good luck .... Mike
    Dec 2015
    Oakley Utah
    That's what I did. I used the bulb designation and searched for LED equivalent. Further research may be needed to find ones that are Can-Bus ready.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Default Info on using LED bulbs on a Can-bus
    https://www.autobulbsdirect.co.uk/bl...ix-with-video/ i particularly like the straightforward explanation and solutions here.
    https://www.lazerlamps.com/blog/post...ith-can-wiring this is more of a generic explanation of can-bus systems, but is quite good I think
    https://www.digikey.com/en/articles/...n-of-can-buses this is more technical, for eggheads like me
    Amazon search for can-bus compatible bulbs https://www.amazon.com/s?k=Canbus+co...ref=nb_sb_noss
    Do any of these help?
    I know that some of the LED accessory lights used on Spyders have a small capacitor-looking device in the positive wire (for this reason I believe).
    2014 RTL Platinum
    Mar 2021
    Jul 2018
    Germany
    Ok - the project is killed..
    Thank you all
    Greetingsfrom Germany
    Dec 2015
    Oakley Utah
    Thank you all
    What does that mean?
    2014 RTL Platinum
    Jul 2018
    Germany
    That means the project ist died ...
    I was discouraged by the quality of some of the replies I received
    Sep 2017
    INDIANA, USA
    Default So Sorry
    Most of the replies seemed to be helpful. I will admit that I was a little confused at the beginning. Yes, things are a lot different here in the USA. Hopefully everyone can get on the same page and move forward. Please read the posts and see if they are helpful. Questions, just ask. Little Blue.........
    ENJOY YOUR LIFE WITH A SPYDER
    Dec 2015
    Oakley Utah
    Some of us put considerable time and effort into trying to understand and solve your issue.
    2014 RTL Platinum
