2015 RTS Belt drifting a bit after tire change
Put on a Riken Raptor tire, replacing a Kenda Kanine. We changed no settings.
The belt has always sat about a dime distance on the rear sprocket to the inside flange. After getting the tire mounted last night we ran the bike while the rear was in the air and all seemed well. The belt reset itself where I expected it to be and while running the wheel belt did not drift in and out.
Any help greatly appreciated
Willie aka Bill
Below are 4 pictures I took in sequence.
1 This is where the belt ran before we changed the tire. Maybe a tad closer to the inside flange
2 About where the belt was when I came outside after mounting the tire last night and driving about 20 miles
3 Slowly drove up the street stopped and took picture. Wife was driving and I was walking behind to see if I could see anything obvious
4 Drove at about 35 mph up and down the street
The belt will move outward when you backup and then take a little time to get back in place when you drive forward again. So make sure and drive forward for a while and then check belt, without backing up.
My Spyder
Ozzie Ozzie Ozzie
Those belts move around a helluva lot more than most expect - watch what it does as your wife reverses the Spyder up the road for 5-10 metres or so!!
From what you've shown us in those pics, I'd say your belt is pretty close if not exactly where it needs to be - fiddling with it to get it any 'better' will rapidly become an exercise in frustration and you'll end up disappearing down the rabbit hole of ever diminishing returns!!
So take the win you got by not having it move much during the axle pin tightening sequence, and just.......
Yeah, you got it.......
Ryde More, Worry Less!
2013 RT Ltd Pearl White
.... A few years ago I saw a video someone had made showing what the drive belt was doing while He drove His RT around ( including in reverse ) ..... the belt was almost constantly moving side to side, especially when in reverse .... I've been posting this for years ..... maybe it should be a Sticky ..... Mike
I traded for my Spyder a year ago this month... ( July ) and I don't think I ever noticed this kinda high pitch little whine from near the rear wheel until about 2 or 3 months ago, when I put a new set of tires on it. I did all the work myself, except I took the wheels to a shop to have them Balanced. NOW at about 48 mph it starts, and about 65 mph it pretty much goes away. At first I thought it was the rear tire on the road .... but now I think it might be the drive belt ... anyone else ever had this problem???
Reason: Removed spaces before punctuation marks :-)
