How many 2014 - 2019 RT's are fitted with '13 Heat Scoops? Any benefits? Negatives?
How many Spyder RT/RTS/RTL's with the 2014 - 2019 bodystyle have installed the 2013 Heat Retention scoops (The scoops under the mirrors for those that might not know).
And did you find a significant reduction in driver crotch heat? Any negative issues after installing them? Heat Mitigation scoops front.jpg Heat Mitigation scoops side.jpg
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020
How many Spyder RT/RTS/RTL's with the 2014 - 2019 bodystyle have installed the 2013 Heat Retention scoops (The scoops under the mirrors for those that might not know).And did you find a significant reduction in driver crotch heat? Any negative issues after installing them?Heat Mitigation scoops front.jpg Heat Mitigation scoops side.jpg
Yes, it makes a big difference for me. No down side.
Had them on my 2013 RTL. If I could find them and the installation instructions I would put them on my present Spyder.
2017 Champagne Metallic RT-S SE-6 Rivco Dual Flag Holders; Slingmods Highway Pegs; (Hate Them) Airhawk Seat Cushion; Show Chrome Black Touring Rack w/ Risers & Touring Windshield; RAM X Mount For TXTAG; TackForm Phone Mount; Lidlox; Magic Mirror Mounts; Guardian Bells; WOLO "Bad Boy" Air Horn; Dual USB Power Outlet With Voltmeter; Spyderpops Full View Mirror Turn Signals; Large Brake Pedal; Kott Grilles; Large Mud Flap; BajaRon 3 Piece Sway Bar, Last But Not Least, Kuhmo Rear Rire, Vedrestien Fronts.
They were put on my 2013 for the recall and they worked so well I put them on my 2015 right after I bought it. Biggest difference on the 2015 was the glove box went from hot to cold. It's pretty obvious that they keep everything under the tupperware much cooler.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Safe Rides,
IBA 70020
I'd also appreciate some pics like I posted of the scoops on a Black Spyder, ANYONE out there with a Black Spyder with the heat scoops?
Safe Rides,
IBA 70020
Installed on 2012 RTL love these scoops.. The 2014 RTS did not require them but it has an insulated glove box
Since I have the '18 Anniversary edition I was pondering adding either some gold or black carbon fiber with gold weave treatment, either to just the front glossy part or the black textured rear part of the scoop. Talking to both wrap shops and hydro-dip shops to see if I can come up with something. Wondered if anyone changed the black on black on black combination.
Safe Rides,
IBA 70020
The trade off by adding the scoops and no longer being able to run the optional adjustable air deflectors for rider and passenger was not worth the sacrifice of decreasing rider and passenger comfort.
The use of much better insulation on the underside of the body panels reduced or removed heat while moving and while not moving in traffic or other times.
