Results 1 to 16 of 16
    Dec 2018
    Dallas
    Default Belt Tensioner, use it or do not use it?? What’s y’all opinion on that.
    Hey all, I did remove my original belt tensioner from my F3T but feel uncomfortable with the vibration that starts when I’m doing 75 MPH to 80 MPH. I do have the Spyder F3T 2018. What’s y’all opinion on that. The only concern that i have is that my belt seems to move on the rear sprocket left to right. The original belt tensioner , since it was plastic< just melted away with the side of the belt rubbing on it. Thanks in advance for y’all’s opinions.
    2018 Spyder F3T , Bright White
    Quote Originally Posted by Clopez68 View Post
    I'm Anti-belt tensioner ...... I lowered my tension to 160 lbs with tire on the ground .... and have No noticeable Vibes .... There have been folks here that had the tensioner pulley FAIL and it shredded the Drive belt. ... That's about $500.00 repair ( not including towing etc. ) .... If that thought doesn't upset you ... then do get it ...... OR just live with the minor irritation. ...After all it isn't a Cadillac it's an Mtc. ..... good luck .... Mike
    Northern Kalifornia
    Readjust your belt tension, slow down a bit and the vibration will go away. Your belt will move from side to side. So as long as it does not move off the edge of either sprocket you're good.
    Sep 2016
    Chillicothe, Oh.
    I don't want one, but that's me. If you install a tensioner just keep an eye on it from time to time. They can fail and belt damage may occur if they do.
    2015 RT , Black
    Yes that can work ..... however IMHO it won't help you .... There's NO warning light on the dashboard like you would have with FOBO ( which I recommend for any TRAILER being towed ..... good luck ... Mike
    Mar 2017
    Salisbury,NC
    I have never used one. Did lower tension to 160
    Aug 2019
    Stoughton, WI
    If it came with one, use it. If not, don't.
    2022 RT Sea To Sky
    Clinton, MS
    I've tried the lower tension and all it did was change the MPH range that the vibration occurred. I'll use it and keep check on it.
    Mar 2008
    Hesston, PA
    I'm a fan of belt tensioners...There's a reason BRP started installing them from the factory...Changing the belt tension just moves the vibration to a different speed...
    Spend a little more and buy a QUALITY SMOOTH SPYDER belt tensioner...You'll never have a problem...Yes I have one...larryd
    Mar 2017
    https://www.lamonstergarage.com/belt...-idler-pulley/
    I have an OEM tensioner with a Lamonster bearing...
    Harrington, Australia
    Quote Originally Posted by Rattlebars View Post
    My ‘21 RT came with one from the factory. There is no way I am going to modify it, even though Lamonster’s roller is a better unit. If the OEM dampener fails and shreds the belt, there is only ONE party accountable for the repair.
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2020
    CT and ME
    My 2020 F3S came with the OEM dampener. It failed at about 9,000 miles and shredded the belt. My dealer covered it and the belt under warranty. I got the Lamonster improved roller but decided not to install it at the time - with the idea that there is one less thing to fail. Belt tension set at 160 as recommended by several people here. I've ridden the bike for the last 12000 miles without the dampener. But the belt vibrations were annoying. After a 3,000 mile ride to Nova Scotia to do the Cabot Trail, I decided to re-installed the dampener with the Lamonster roller and now the bike is back to smooth running. I'm going to keep it this way and just check the roller frequently.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Quote Originally Posted by Yabbadabbadoo View Post
    Glad to hear BRP covered your loss ..... however if your new roller fails ...... $$$$$$$$$ from your pocket .... unless LaMonster warranties His roller ..... good luck .... Mike
    Member SmackDabb's Avatar
    Jul 2022
    Lecanto FL
    For the cost of these bikes you'd think BRP could at least make some effin quality parts for them out the door. I mean seriously, these machines are cheaply made in my opinion.
    2020 F3 Limited
    2004 Valkyrie Rune
    1998 Valkyrie
    2007 M109R
    Registered Users Ronbo's Avatar
    Mar 2013
    Arkansas
    I put SMOOTH SPYDER belt tensioners on my 2015 F3, made a world of difference to me. A HUGE DIFFERENCE!
    In my humble opinion, I think they are a must!
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Quote Originally Posted by SmackDabb View Post
    1000% agree...
    I don't understand why they are not shaft driven. Sooo much better in all accounts.
    Tim
    PS... LOVE LOVE LOVE your Rune. I'm a GoldWing guy. The Rune is a work of art. I almost had one of those once. I should have pulled the trigger.
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
