Results 1 to 14 of 14
    Jul 2022
    Nashville, TN
    Default What's this Extra button next to Ignition Key area for?
    I and my wife are new owners of a 2017 Spyder F3 SE6 Limited and noticed there is an extra button on the right side of the ignition key area. I looked in the manual and a picture of that area shows a button on the "left" side for the heated handgrips but a "blank" area on the right side. It is a factory button for sure that lights up and looks like the icon on it is that of a power symbol. The previous owner had no idea what it was for.
    Anyone have any ideas what this button is meant for?
    TIA,
    Dennis and Myriam Bagwell
    Nashville TN
    Last edited by Peter Aawen; 07-18-2022 at 08:49 AM. Reason: Expanded Title to briefly ask question ;-)
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    On my '15 F3S it turns on/off the fog lights.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
    Jul 2022
    Nashville, TN
    Quote Originally Posted by cravenfun View Post
    I checked but this one does not have fog lights. It has blanks where the fog lights would fit, round plastic dummy inserts, but no fog lights.
    Could it be perhaps they could be added and the switch is already there?
    Just weird if that's the case.
    Quote Originally Posted by dbagwell79 View Post
    I'm surprised that there is a switch ..... The wiring for the Fog lights is in your harness though ..... all that's the most important part ..... Mike
    When you buy the fog light package it comes with the switch and the button insert. I have had fogs put on my two RT versions. The F3's were L's...so they came with the fog lights already installed.
    EDIT: I stand corrected on the F3L's. They did NOT come with fog lights. I also had them installed...at the dealer...before delivery. No extra hardware was required for install.
    Jun 2022
    N.E. Fl
    I have fog lights and the yellow switch on my 16 F3-T SM6.....but they don't work, hubby checked the fuses in the Fronk (sic) all good. What are we missing? Switch lights up too...
    2016 F3-T , Blk/Rd
    Mar 2017
    Salisbury,NC
    FOR THE MAIN HEADLIGHTS TO COME ON, ENGINE HAS TO BE RUNNING. maybe same for fog lights. or make sure, they are not dummy blanks
    Mar 2019
    Ruidoso Downs, New Mexico
    Maybe yours did....my F3L did not come with the fog lights OR the switch. There was a 'filler' plug in the questioned spot but I managed to lose it. Don't ask....
    2020 F3L; gone but not forgotten are all the good miles!
    Jul 2022
    Nashville, TN
    Thanks for all the input. I took the side panel off, which houses the fog light filler plug and there is no wiring there. I suppose they put the power switch there, just in case.
    Jul 2022
    pa
    I just ordered a garage door opener for mine they said that would work perfect, got it from slingshot,
    Dec 2018
    Long Island
    Can you post a picture of the button?
    Apr 2020
    Edgerton,WI
    I wired that button for the Passenger Ejection Seat.
    2019 F3L , Covid Blue
    Jul 2022
    pa
    I just installed the garage door opener, works great, there were wires attached to the back of the blank switch I assume they go to fog lights which I dont have. What would I do if i wanted to add fog lights with the garage door opener?
    Member Airjohn's Avatar
    Apr 2021
    Hurricane, Utah
    Default Fog Lights
    I have a 2018 F3 Ltd. Installed a set of Fog Lights in a kit from LaMonster. The kit included the lighted switch that controls the on/off of the fog lights. That switch mounts in the hole just to the right of the ignition key. Initially it worked just fine and really helped out visibility at night. As time progressed, the light switch had to be pushed several times, and sometimes held down a few seconds before the fog light would come on. Got a replacement switch and all was well. This seems to be an issue with premature failure in some of those switches, most likely due to the high current switched needed for on and off. The contacts have to be of good quality.
    Just my experience with the 2018 F3 Ltd with about 10,000 miles on it.
    Regards,
    John In Utah
