Is the F3 sprocket different than RT? IF NOT here was a for sale one https://www.spyderlovers.com/forums/...sprocket-(New)
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
that bolt is supposed to be a one time use according to BRP. so if you don't have a new bolt, just make sure to clean the flange part, end of output shaft, outside of pulley, and torque to 110FT LBS
Reason: fixed ft lbs
Originally Posted by Woodaddict
that bolt is supposed to be a one time use according to BRP. so if you don't have a new bolt, just make sure to clean the flange part, end of output shaft, outside of pulley, and torque to I think 115FT LBS
Smoak did a video on this recently: 150 NMs, 110 ft-lbs.
Doug
”Freedom is not a loophole”
Way to go Fatboy! That rocks!
Peter Pan has struck again!
BRP is reusing the bolts when accomplishing the recall spline inspection.
Take it apart, clean everything and assemble wet with moly lube. Accurately torque to specs, but ensure the oem thread lock compound still prevents the bolt from being threaded by hand until seated.
Moly lube for the win. Prevent fretting before it starts. Accomplish clean, inspect and relube at an interval you decide upon. Will likely last for as long as you own it.
