Results 1 to 2 of 2
    Active Member DickB's Avatar
    Jun 2021
    FL
    Default Here's how to do a Parasitic current test...
    If your battery is going dead after the bike sits for a few days, and the battery tests good or you believe it is good, the next step is to conduct a Parasitic Current Test. It's not hard to do and doesn't take much time. You'll need a multimeter for this test. If you don't have a multimeter in your toolbox, you should. A best seller on Amazon is only $13.
    https://youtu.be/MBnbsrrwMkk
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Most constantly energized devices, such as ECU, regulator; should not exceed about 1 milliamp each.
