SpyderLovers Sponsor
I just got a very nice 2015 F3 - anyone had theirs pull slightly one way?
Hi Everyone
Dave here, I just bought a very nice F3 ( see photo) wow what an improvement
they have made since the old GS & RS models. Quick question has anyone ever
experienced having their F3 pull slightly to the right or left ?
I will be installing new front tires very soon but I was just wondering if there
is anyone that has had this.
Dave
No answer for your question from me Dave, but you look good on that! Congrats from up here in Canada, and Happy pre 4th!
Reason: tour - your; Ongrats - Congrats ;-)
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Thanks Buddy, hope you had a great Canada Day as well.
I decided to move up and get a newer Spyder..
Originally Posted by CopperSpyder
On the new to you F3 Dave!! Try and get a laser alignment when you get your new tires, that may fix any pulling you have.
I would love to but the closest alignment is Las Vegas Nevada about 600 miles away
F3 Laser Alignment
Hey Dave. Your F3 looks great.
I had a pulling or drifting issue with my new to me, F3T. Handle bars were wonky with the left side higher than the right. I did a rudimentary alignment with lasers I cobbled together and instructions from Oz. The F3T is now much improved but not yet perfect. I'm hoping to get a true Squared Away Alignment when Joe and Ann return to Las Vegas at the end of summer. Joe told me there will be some folks in Tracy getting together to get laser aligned later this summer. Perhaps we can meet the group in Tracy?
Reason: Many don't get to see Post titles, just the Thread title! :-/
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Have you checked the air pressure in the front tires just to make sure that they are the same?
Sounds like a good road trip to me with a little one arm bandit action!!!
I had a 2014 Spyder RTL that pulled to the right. I switched to Federal EVO tires ( which are no longer available) and had it aligned by Squared Away Joe and Ann. That took care of the problem. I now have a 2021 Spyder RTL which drifted to the right (not as bad as the 2014) with the original Kenda tires. I switched to the Vredestein tires that helped it still has a slight drift not bad it seems like it depends on the road crown some roads it goes straight down the road no drifting what so ever. If I ever come across Joe and Ann from Squared away I would have them check it for me.
When Joe and Ann get back from the demo trip it will be well worth your while to take a mini vacation and go to LV to get the laser alignment. But get the new tires first. My RT pulled to the right even after a laser alignment because of the factory Crapendas. New tires cured the pull problem. Also, buy or make a dual fill air hose so that you can fill both front tires simultaneously to the same pressure. Spyders are sensitive to uneven pressures.
Hi Everyone
Dave
Radial tires CAN cause pulling all by themselves.... There are many stages to produce a tire and if ANY of the belts/plies move off center even slightly during the molding process... The newer higher quality stuff doesn't have as much of this but I just put a set of Michelin PS4S's on my McLaren and it drifted left where it hadn't before. Luckily, they aren't directional so I could swap them side to side in the front and NO MORE drift!
Replacing the Kendas will most likely solve your problem... ;-)
Chuck
Originally Posted by Haze
F3 Laser Alignment
Sounds Great if you get any new info give me a call please Thanks 209-887-3283
Yes that is the first thing I did. I will be replacing the front tires I hope this week. maybe that will cure it
I put Michelin tires on my old 2008 GS and it made a world of difference
