The Truth about LED bulbs - Don't Buy LED Bulbs Before Watching This!
Led bulb for headlights
Originally Posted by larryd
Thank you…..very informative.👍
Headlight Revolution has a number of informative videos like this; they seem like a reputable company.
It would be interesting to know how popular LED headlight kits from Lamonster, etc., stack up against these specs. Led shape, size and location? Heat dissipation? Driver type and location? Wiring and connectors?
2014 RTL Platinum
Plus things have evolved quite a bit since that video was made 2 1/2 years ago.
Peter Pan has struck again!
Does anyone happen to know the series designation of the OEM halogen bulbs for the 2014 RT headlights?
2014 RTL Platinum
... I bought 9005 / HB3, they fit fine ..... good luck ... Mike ..... I suggest you try the above Fahren LED's ... I don't do much Night riding, because of Night Blindness ( 75 yrs. old ) .... but when I do these bulbs light up the road very,very well
Yes, I think they are 9005. These are the 9005-compatible LED bulbs carried by Headlight revolution; https://www.headlightrevolution.com/...cecategory:asc
I doubt Lamonster, Tricled, etc design their own bulbs, so I wonder which manufacturer theirs most emulate and how they fare against the criteria mentioned in the OP's video?
2014 RTL Platinum
I use them and have since getting the byke new (2016).... They are still working!! I had one of their DRL's fail but the headlights are SOLID! The drivers are average size and not an issue as there is PLENTY of room in there to put them, the wiring and connectors are weather tight and solid as well.... The light pattern & quality is MUCH better than stock of course. Not sure I would "venture" to change away from them seeing as they have been so solid for me.... I believe I used the ones by Fahren on my wife's Camry with good results....
Chuck
Can you clarify which brand you're talking about?
2014 RTL Platinum
The next time I need headlight bulbs, I may get these I think. Watch the video. https://www.headlightrevolution.com/...4_2?quantity=1 9005/HB3: S-V.4, although the Fahrens that Mike favors look good also at a fraction of the price...
2014 RTL Platinum
Is this the one, Mike? https://www.amazon.com/9005-HB3-Head...29670799&psc=1
Is the driver built into the housing? It seems to have great specs for the price.
2014 RTL Platinum
The next time I need headlight bulbs, I may get these I think. ... S-V.4, ...
About a year ago, I got new bulbs for my 'new' van and my wife's car. I got Morimoto 9005 2-stroke 3.0 for the DRL bulbs on the van and S-V.4 bulbs for all the rest. VERY impressed with them all.
I probably would have gotten S-V.4s for all of them, but the Morimotos have a DRL function that works at lower intensity. None of the others that Headlight Revolution tested have that. Works well in my van.
I have TricLED bulbs in the Spyder. Had I known about the others, I might have waited.
HER ride:
2017 RT-S SE6 Pearl White
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
Interesting. When I went to buy led bulbs for my GMC Canyon on HR's website, there was a cautionary note wrapped in legal mumbo jumbo, that said basically the headlights aren't legal per DOT to be used on-road. But their video promotes them for the truck. I've since researched this issue a little and it seems aftermarket LEDs are too bright for current highway use because of outdated regulations (some states, like NY, have even stricter brightness standards than DOT, using the old 'candlepower' measure). Check out this 4 y.o. article https://www.poughkeepsiejournal.com/...ay/2356307002/
So, I ordered a set of Fahrens from Amazon at 1/4 the price. That way I won't be out so much money if the lighting police nab me.
2014 RTL Platinum
I realize that, Mike. I was just kidding about getting nabbed. But, it may explain why my truck came stock with halogens (that manufacturers have to redesign headlights specifically for LEDs). Didn't make sense to me before.
2014 RTL Platinum
HIDs for me
I bet I said "hu" about a dozen times during that video. (That's a good thing)
What the police do here in mexifornia (if they have the time to make the stop) is issue a fix-ticket and send you to a certified auto repair station to have the bulbs verified. Something I saw just the other day was a car with a blue headlight and a white headlight. They didn't seem overly bright but they sure as hell caught your attention.
Actually, I wish there was universal enforcement. I sure get tired of being blinded by oncoming vehicles (usually jacked up trucks) blinding me with their low beams!
2014 RTL Platinum
Actually pick-ups don't have to be " jacked up " to cause issue .... I have yet to see a pick-up whose headlights arn't ...TWO FEET HIGHER than a cars.... that's the real problem..... also folks whose headlights arn't properly aimed .... JMHO .... Mike
What really T's me off are the pickups run their dam fog lights when there's no dam fog. Anybody else with me here?
Don’t forget all the passenger cars and their so called driving lights....both of these should be called BLINDING LIGHTS!
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
