RTS windshield hardware
Need oem windshield mounting hardware for my 2015 RTS windshield.
Thanks,
Chris
Hello everyone,
So I purchased a Freedom windshield from a member here for my 2015 RTS. When I purchased the bike it had an aftermarket
shield on it and I assumed it had the same hardware, nope. The holes on that shield are like 7/16 while these are 1/4. I called LaMonster and the lady there knew right away, she said their windshield would fit stock hardware but it sounded like I had an aftermarket shield on mine.
Bingo .
So if anyone has some OEM bushings and grommets or knows of a fix I'd appreciate it. Push comes to shove I can cut these rubber grommets and try to feed them into the shield, but the Bushings might be a bit harder as I live in sticksville.
Thanks in advance,
Chris
Reason: Merged threads...
