Results 1 to 23 of 23
    Active Member SteveandBelinda's Avatar
    Canton, MI
    Default What's a good replacement Battery for 2014 RTL?
    Has anyone had better luck with some batteries than others, for their RT? I had to buy one at Napa in September of 2020, most all the time keep it on a trickle charger, but had parked in driveway today, and went out to put in garage tonight, and turned the key on, pushed button to start, screen was white, then everything went black. Put two different trickle chargers on , and they both showed error or dead battery. Now the problem is looking on Napa's site about warranties, it states if it is The Legend series battery, the warranty is good for 18 months, means I am out of warranty by 4 months, and may have to pay for a new one. I believe that last battery was the original, because I don't remember ever changing a battery till 2020.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    May 2017
    Mesa, Arid-Zone-A
    Problem may be using a trickle charger. It will kill our small bike batteries by continually charging. Best to switch to a suitable motorcycle battery maintainer. I have always had good luck with Yuasa batteries. Good luck..... Jim
    Semper Fi
    Sep 2015
    Chilliwack, BC. Canada
    For my money, I’d stick with Yuasa. Every bike I’ve ever owned had a Yuasa battery. All, that is except my first bike, the Royal Enfield....it didn’t have a battery.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    western Colorado
    I use Deka brand battery with no issues.
    Canton, MI
    That is what I use, a Battery Tender or Battery Tender Jr.
    Canton, MI
    Anyone know what model of Yuasa battery is for the 2014 RTL?
    Northern Kalifornia
    Quote Originally Posted by SteveandBelinda View Post
    Take the old one in with you when you go to buy a new one and they'll match it for you. I think in some states it has to be an exchange process.
    Just remember it's not only the dimensions & the volts/type of battery that you need to match when you're replacing your Spyder battery; you also need to match &/or better the Cold Cranking Amps & the Amp/hour rating!
    Bossier LoUiSiAna
    Gonna be lil difficult finding part/batteries thanks to supply problems YTX24XL. 350CCA is what had in 13STL. There are some comparable replacements, YUAUSA has definitely performed better.
    preferred charger/maintainer believe 5y warranty
    Mar 2015
    Fritch, Tx
    When the OEM YUASA in our '14 RTL died a couple of years ago, I found the exact replacement by the numbers on the battery at Amazon Prime. Had it in hand in less than a week at a better price than I found online or local shops.
    I also don't use a trickle charger unless I know the Spyder or any of my bikes will sit for more than a couple of months. The charging system in your machine is the best way to maintain a battery.
    Those who say " I can't" will always be right.
    Yuasa YUAM7250H YTX24HL is the factory fill battery. The new battery should have a note with it saying when it was filled and one should charge it for 24 hrs. before installing and use a Battery Tender Jr, not a trickle charger as canamjhb said.
    Canton, MI
    Can't find one. All dealers I have called have said they have been on back order for about a year.
    Canton, MI
    All Yuasa batteries are back ordered. I have my bike in driveway, and can't even get in garage because emergency brake lock. Can the bike be jumped like a car, just to get it in garage? I'm really anal about keeping an eye on my bike. Also, Battery Tender Jr. is what I use.
    Mar 2019
    NEBRASKA
    I use a Duracel from Batteries Plus(everywhere) for the 2 yr FULL warranty(fails a load test) and their usual 10-20% discounts (10%) for just ordering online. I also use a tender/maintainer when not in use. With discounts it was 110-115. Its working great since may 21. Duracell Ultra 18L-BS 12V 330CCA AGM Gray Case Battery - USA
    CYL10018
    Yikes the new price is 180$ !! but I'd watch for specials!!
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Sep 2014
    USA
    Go to batteries plus and get the extreme battery. That was my replacement last week.
    Dec 2015
    Oakley Utah
    There was a whole discussion about replacement batteries last week on a different thread.
    2014 RTL Platinum
    Mar 2019
    NEBRASKA
    CYL50LBS
    Yuasa 24HL-BS 12V 350CCA Flooded Powersport Battery
    1 pack
    $118.99
    Qty
    $118.99
    Update
    Remove
    This is available at my local batteries plus
    Read this and weep! https://www.spyderlovers.com/forums/...hlight=battery
    I ended up getting the Xtreme from Batteries +.
    Mar 2015
    Fritch, Tx
    On this battery issue, has anyone used an Odessey? I love the way the perform in my bikes but chose to replace the Yuasa in the Spyder with and OEM.
    If you use your CAR battery .... leave the engine off .... connect car to Spyder Battery ..... your Spyder should start, if not then just release the Brake ..... good luck .... Mike
    You could always just release the Park Brake Cable at the rear wheel in order to let it roll freely!
    2 x 12 mm spanners & less than 5 minutes should see you sorted & your Spyder in the garage, altho it might pay to have a couple of chocks on hand, and maybe someone to help with pushing it - our Spyders aren't exactly lightweight!
    Sep 2014
    USA
    If the battery is toast probably will not start even with a jump. You can hook up a jump pack to at least release the brake. Then push it into the garage.
    Nov 2018
    Claremore, Ok.
    I found a Banshee battery same size but with a 430 CCA and 4yr warranty. Less than $100.00. google Banshee battery to find it. I also have a NOCA jump starter in my frunk and the connector wire to battery hooked directly to battery and the connector stubbed out of battery cover. I also have a 10 gauge wire from battery along the side, under the Tupperware up to under the right speaker hooked to a BMW style plug receiver to plug in my cold weather jacket and pants.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
