Results 1 to 22 of 22
    Mar 2021
    Haven, Ks
    Default Too hot to handle - heat on inner thighs fm glovebox - any suggestions?
    2019 RTL three cylinder 1330. I noticed last week and then again today in a big way that the heat on my inner thighs by the little glove compartment was just unbearable when riding in the heat. Engine temperature was normal or a little less than usual so no overheating problem but the engine heat coming out under the front of the seat was so hot that I had to ride for short periods standing up just to get away from the searing heat. I know that some of the older twins had heat disbursement issues but have not heard any complaints about the 1330. I do have an Ultimate seat but that shouldn't have anything to do with it. Any suggestions?
    Bartender
    2022 Spyder Sea to Sky
    Sep 2020
    Middletown, NJ
    If you haven't already done so, replace the Cat with a cat-delete pipe. It's a space heater!
    2020 RT base , Chalk White
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by RayBJ View Post
    +1 on the cat delete. I bought mine from LaMonster Garage. Didn’t totally remove the heat, but did greatly diminish it... and LaMonster started this website....give hime a few bucks.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    IMHO I don't think the " CAT " has anything to do with the Heat ..... I drove my RT w/ 1330 engine for years before I re-moved the CAT .... never had a Heat issue .... last year I was stuck in traffic on the Verrazano Bridge for 1/2 hr. at ..... 115- F .... and I didn't feel any heat. ..... If your Spyder isn't over-heating I can't imagine what could be causing that kind of Heat .... Good luck .... Mike
    Sep 2015
    I know that when I had my cat removed, the heat rising by the seat was greatly diminished, but the heat in the glove box is still actually too high to leave a cell phone in for a full days trip. The way I see it, the heat under the seat is coming from the cat and the heat in the glovebox is coming from the engine. Just my 2 cents, and it may not be worth even 2 cents. '14 RTS
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Apr 2019
    Clinton, MS
    Mike, on this one we will have to greatly disagree. Come on down to south LA, MS, AL, GA, FL and do that right now and you will get all the heat you ever wanted coming up off the bike. Ann suggested that I remove the the plastic panels off the bottom, helped a bunch. Put on a Ceramic coated cat delete and it helped a bunch more. Not uncommon for the dash temp gauge to read 135+ in these situations when stuck in slow moving traffic.
    Ed, if what you are experiencing with the 1330 RT is Normal .... then why arn't thousands of others complaining about it ???? I hope you arn't wearing Shorts ..... good luck ..... Mike
    Mar 2008
    Hesston, PA
    What many of us have done is install the heat management kits that BRP had introduced as a fix for the heat problems on the troubled 2013 RT's...
    I along with many other here on the forum have installed these kits and the heat problem for the glove box area goes away...
    There was a recent post in the last 2 weeks with someone looking for the "do it yourself" directions...Most dealers had templets issued to them to do the recalls on all 2013 RT's...There is NO painting required...But precise cutting is a MUST...larryd
    Here is a post about vent kits...https://www.spyderlovers.com/forums/...tallation-Help
    Dec 2015
    Oakley Utah
    Maybe he's looking for a solution that doesn't contribute to atmospheric pollution....
    I'd suggest the RT vent kit, if you can find one.
    Maybe one of our enterprising d-I-y members can explain how to divert the heat generated by the engine away from that pocket in the bodywork where trapped heat causes the phenomenon described by the O.P. in the absence of RT vent kits (which are probably no longer being produced)
    2014 RTL Platinum
    Well waaaaaaaaaaaaaaaaaaaaaaaaay back I installed small computer fans on my 08 GS and that fixed the heat issue .... check Flea-Bay .... they come in lots of sizes and cost only a few $$$$ .... and they mostly are shipped free .... of course this DIY ..... Mike
    Dec 2015
    Oakley Utah
    I've done the same with our small travel trailer, particularly to remove heat from the back of the fridge.
    It's worth a consideration. Where would you mount them and is additional venting needed do you think?
    2014 RTL Platinum
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    Vent kits are still available on Amazon and eBay. I had a 2013 that got the vent kit installed along with a few other improvements that were part of the recall, the vents worked so well for the problem you describe that I put them on my 2015 right after I bought it. I also put them on a friend's 2011 and they made a big difference.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Nov 2018
    Claremore, Ok.
    I put the vent kit and a cat-delete from RLSexhaust.com and I get NO heat from under engine. I can even keep a Hershey bar in the glove box, as long as it's not sitting in the sun.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    LOL - So says Central Vermont!
    Now come down here, to the Southwest and test drive one with and one without.
    You'll quickly change your mind.
    That is if it hasn't gotten too well done!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Mar 2021
    Haven, Ks
    I guess I will find out if the cat delete helps or not. I had earlier installed a RLS muffler and did not install a cat delete because I didn't want the extra level of loud exhaust but after four days riding in 100 degree temperatures and having the upper side of my legs literally baked to the point of having welts on the top of my legs, I installed Lamonster's cat delete to see if that would help. I did install the baffle. The heat coming up on my legs was so intense that I finally resorted to pouring bottled water on the top of my riding jeans from time to time. I would refresh the water soaking about every 45 minutes. This allowed me to complete the intended routes and get back home. Now I will find out if the cat delete helps. I don't know about the "vent kits" and if necessary will check those out but I didn't think they were available for the later models. I may have increased the heat levels by having flashed the ECU with the Stage II Monster flash, I don't know. What I do know is that without something to change the current situation my 2019 RTL is not rideable when the outside temperature is over 90 degrees. I'll post when I know if this helps. I will comment that the increase in exhaust noise is more than I wanted but tolerable if the cat delete helps.
    Bartender
    May 2019
    Mt. Juliet, TN
    This thread certainly caught my attention. 2020 F3-T I would like to get above discussed heat relief on lower legs. You mention a Cat Delete modification. Would one of you kind souls give me a few highlights about this mod:
    >Is the mod simply deleting the catalytic converter?
    >if so, do you replace with exhaust pipe(s)?
    >Would there be any compromise to enforce warranties on the vehicle?
    >>Any other intel you want to offer will be much appreciated.
    Gets hot in the summer in and around TN. Thanks all. GOOD STUFF ALWAYS
    Mar 2021
    Haven, Ks
    Response to Seagravesg. The cat delete is a replacement exhaust component available from several sources but I chose the version available from Lamonster one of our site sponsers. It simply replaces the catalytic converter with a custom made exhaust pipe and is simply plug and play. Got mine delivered last night and installed it in about 45 minutes. It is easy to do and but for the retention springs could be accomplished in about 15 minutes. You can retain your factory muffler or replace it if you wish with any number of alternatives. The retention springs are a little fiddly to put back in place but with a little patience are really easy to reinstall. I don't know if this will solve the problem or not. I don't see this as a warranty issue at all and keep in mind that it is only a problem when the ambient temperature is high and you are traveling long distance at highway speeds. I was on a four day ride in 100 degree temperatures and traveled over 1500 miles in that period. In ordinary local or short distance rides it would have not been a problem.
    Bartender
    Mar 2019
    NEBRASKA
    Quote Originally Posted by larryd View Post
    I put air scoops on a 2012 -NO CUTTING OF PANELS - I just assemble the scoops and removed the clear wind deflectors and the attached the scoops with the one screw . I've had great success and no rubbing of the panels from the scoops. I only used the scoops ...no brackets or insulation. I'd be hard pressed to do anything on my 14 RT-its fine. Now I wlll say the 12 RTL gets to about 1/2 way on the temp gauge sitting in traffic but it's totally ok.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Quote Originally Posted by Bartender View Post
    Considering how much dis-comfort you are experiencing I'm surprised you didn't Wrap the new pipe with automotive HEAT Tape .... it would have been very easy to do Before you put the pipe on .... good luck .... Mike
    May 2019
    Mt. Juliet, TN
    Trying to decide about whether I want to replace the cat converter with 'S' pipe (cat delete) because of the noticeable heat the cat produces. The replacement pipe will result in some loss of back pressure, do you also notice any loss of torque or acceleration on the vehicle with that conversion?
    Sep 2015
    W
    Quote Originally Posted by seagravesg View Post
    I didn’t notice anything, but then again I’m not an overly aggressive rider.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Northern Kalifornia
    Put the baffle in the cat delete and you won't notice any difference in the low end torque. I/we ride in 100 degrees + on many summer rides. I have a 14RT with cat delete, stage 2 and I run Baker's air wings and sit on a Misty Mountian seat cover. No heat issues at all. If you want to talk heat, go take a spin on a Harley in the summertime. I've owned several, I know.
