2018 RT Ltd with multiple Engine codes - runs but won't select gears??
Hi, have a 2018 RT Limited Spyder with issues;
Orange quotation mark, E brake light, and CHECK ENGINE light stays on with the key off.
4 codes U0122, U0100, P0680, B100F
Runs great, revs, Idles smooth, but will not go into any gears.
Any help please?
Reason: Revised title to briefly ask question... ;-)
Any help please?
# 1. - is your foot on the BRAKE pedal, it won't shift unless it is ..... #2.- add one tablespoon of Brake Fluid into each reservoir ( under the seat at right rear side ...... Mike
When was it last serviced?
The orange/red ! means your parking brake is on. Push the P button to turn it off (with your foot on the brake)! To shift when stopped you need to have your foot on the brake. When you turn the key off, it takes 20-30 seconds to shut down. Check the brakes for worn pads or fluid leaks. Most likely the fluid needs flushing and possibly the pads need replacing.
Adding a little brake fluid doesn’t fix the reason it’s low.
Forum
RT Shop Talk
