Page 1 of 4 1234 LastLast
Results 1 to 25 of 89
    Apr 2020
    Edgerton,WI
    Question What’s your average MPG using what Octane Fuel?
    What’s your average MPG using what octane fuel, RT or F3,F3L?
    When I checked twice on a recent trip, With trailer and two up riding, I averaged 33.5 mpg with Monster Fuel Injection Stage 1 ECU upgrade using premium.
    So, the consensus average is about 35mpg.+-
    Kool, my mini van gets 27mpg…….gives me more reasons to ride the spyder.
    2019 F3L , Covid Blue
    Jan 2021
    northeast pa.
    1600 miles on mine, never checked it..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Mar 2021
    Maryland
    I am a more spirited rider, just recently switched to 87 (4 tanks) been getting on average about 31.2 down from about 31.7 with 93. Only noticed a slight difference in performance when driving on the higher end of the scale on the highway.
    2020 F3 SE6
    2020 F3 , Black
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Around 33-34 on my regular commute using 87. 2014 RTS.
    I usually use the cruise on the highway set at 65.
    I don't ride distance, any more than an hour and that seat starts to hurt. Trying to get a Laam seat, but he's impossible to get hold of....
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    33 miles per gallon the last I checked. This year I've been burning mid grade 89. No issues, vroom vroom!
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Between 35-38 using 87. I use top tier gas only.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    I have a 14 RT and avg. between 38 & 40 MPG's ( the ONLY accurate measurement for MPG's is on a DYNO - for lots of reasons ). I use whatever 87 w/ethyl I get for the lowest price available ...... good luck ..... Mike
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by bikerchris1270 View Post
    So far, it’s enlightening to read of the folks using a lower octane fuel, with no issues……
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    With my 2020 F3L I am getting 38-42 running 91 premium, ethanol free. Usually Shell, Sinclair or other top tier brand. I do not use ECO mode.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Feb 2022
    Washington
    I have a 2013 RTS SE5 running 87 from the cheapest per gallon price. In town only so far and not fast accelerating (no fun) I get 31-33mpg. Currently have only 14K miles in it.
    Mar 2015
    forrest above Reno, Nv
    2014 RTS with Stage 1 flash and modified intake------- 38 to 40 with 91 octane fuel. There are SOOO many variables for fuel milage though, speed being one of the largest.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2019
    Stoughton, WI
    I consistently get 2-3 mpg better using ethanol free gas versus 10% ethanol. That said, I get as low as 29sh mpg at 80mph across SD I90 with all my luggage installed. With the same luggage at slower 50's mph, I get mid 30's. No luggage/locally, I have no problem getting near 40mpg. This is with my Fuel Moto tune installed.
    2022 RT Sea To Sky
    Sep 2020
    Middletown, NJ
    I have a lead hand so I'm happy to get ~30 MPG on my RT Base using (mostly) 89. I measure my enjoyment by G-forces, not MPG.
    2020 RT base , Chalk White
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    35 MPG
    I have always used the least expensive 87 gas available which is typically either Rebel or Arco
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Feb 2013
    Edinburg, TX
    I burn mid-grade E-10, ride mostly one-up, not heavily loaded, and use cruise-control everywhere (to not aggravate my arthritic hands).
    Life of vehicle (109,000 miles): 37.35
    Last 6,500 miles: 38.20
    Last 9 tankfuls: 39.27 ..... (Because of my new K&N Air Filter? I dunno.)
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    In all my 1330's (three now), I get on average high 30's in all three. A couple of times....low 40's. I check almost every tankful.
    I do not use the mpg stuff the bike puts out. I zero the trip meter at each fill up, fill to the same level each time, and divide miles driven on the tank by gallons to fill. I use 87 with 10% ethanol. I have been using low octane for many years now and have noticed NO difference in operation or mileage when I quit using premium. About 2015.
    Also had 4 998's. Always used premium in them. Mileage was in the low 30's. About 10 mpg lower than the 1330's.
    There have been a few threads about low octane vs. premium, performance vs. mileage. All are interesting reads. My bottom line is printed above.
    Northern Kalifornia
    2014 RT SE6, stage II, K&N air filter, cat delete with baffle, and factory muffler 38/40 MPG. I use ECO most of the time. Run 91 all the time and have bumped 45 MPG a couple of times and 33 MPG a few times. Right now I'm tracking long term MPG by averaging figures over a month or two and see how MPG changes if any. Something I noticed popped up but I can't confirm it yet, is that I'm possibly getting better MPG at 65 MPH than I was at 60 MPH. The 1330 seems to run smoother and quieter at 65 than it did at 60 before the stage II upgrade. Could wishful thinking or just imagination. I'll have to keep on tracking my MPG to figure that one out.
    May 2017
    Mesa, Arid-Zone-A
    Running premium exclusively for 3 years and almost always on secondary roads (not interstates) I always got 40 MPG. .....Jim
    Semper Fi
    Durham,Maine
    There is no real good reason to run high test, unless your one of these guys that like to mess with your ECU!! the bike will run just fine and your smiles for miles will go up in your bank account!
    2012 RTL , Pearl
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    my 2011 RTS got 33.7 last week only time I have really checked it . my bike is completely stock , riding 1 up . average speed 55 to 65 & mostly local highways. High Test Fuel . only has 17,600 miles on it . Ride On !
    2011 RTS Spyder
    INDIANA, USA
    Default Fuel MPG
    ...I agree with you on that mileage thing. You get what you get by the way you run/ryde your Spyder..
    I have gotten up to 40mpg but my normal is around 30 - 32 mpg.
    Ryde and Enjoy your Time.
    Stay Healthy. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Dec 2018
    Long Island
    A quote from BRP web page:
    For Spyder models, your machine will perform to its highest potential and best performance on 91-octane fuel with no ethanol. That said, you will not damage anything if you use 87-octane fuel with no more than 10% ethanol, it just won’t perform top its full potential. Ryker models perform well on 87-octane fuels. Do NOT use E15 or any fuel with more that 10% ethanol in any recreational vehicle as this will damage the engine.
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    On a trip across Canada 2 up towing a trailer. Using 91 or 87 depending, sometimes no 91 available. Not keeping an accurate account, but seem to be averaging 16 Km per litre regardless.
    Keep track of the gas prices in Victoria BC. If 91 octane is the same or less price than 87 octane in Victoria, good deal.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Apr 2022
    SC
    35-38 grins per mile 91-93oct
    Oct 2021
    Climax Springs MO
    Wow! Looking at the gas mileage some of you are getting I may have to look at my driving habits. Riding 2 up most of the time I'm getting 32 to 33 mpg using 91 octane no ethanol. Maybe I'm having too much fun!
    2021 Can Am Spyder Rt Limited
