What’s your average MPG using what Octane Fuel?
What’s your average MPG using what octane fuel, RT or F3,F3L?
When I checked twice on a recent trip, With trailer and two up riding, I averaged 33.5 mpg with Monster Fuel Injection Stage 1 ECU upgrade using premium.
So, the consensus average is about 35mpg.+-
Kool, my mini van gets 27mpg…….gives me more reasons to ride the spyder.
1600 miles on mine, never checked it..
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
I am a more spirited rider, just recently switched to 87 (4 tanks) been getting on average about 31.2 down from about 31.7 with 93. Only noticed a slight difference in performance when driving on the higher end of the scale on the highway.
2020 F3 SE6
Around 33-34 on my regular commute using 87. 2014 RTS.
I usually use the cruise on the highway set at 65.
I don't ride distance, any more than an hour and that seat starts to hurt. Trying to get a Laam seat, but he's impossible to get hold of....
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
Between 35-38 using 87. I use top tier gas only.
2005 Roadtrek Chevy 210P
2020 RT Limited-Chalk White SE6
I have a 14 RT and avg. between 38 & 40 MPG's ( the ONLY accurate measurement for MPG's is on a DYNO - for lots of reasons ). I use whatever 87 w/ethyl I get for the lowest price available ...... good luck ..... Mike
So far, it’s enlightening to read of the folks using a lower octane fuel, with no issues……
I have a 2013 RTS SE5 running 87 from the cheapest per gallon price. In town only so far and not fast accelerating (no fun) I get 31-33mpg. Currently have only 14K miles in it.
There is no real good reason to run high test, unless your one of these guys that like to mess with your ECU!! the bike will run just fine and your smiles for miles will go up in your bank account!
I'm thinking of switching to miles per dollar ...
2014 RTL Platinum
I’m wondering why everyone is so anxious about MPG.....I mean, Why Did You Buy Your Spyder in the first place? Was it because it got such good MPG? or was it to RIDE. If you’re so worried about MPG then get a battery powered unit. No gallons to worry about. Of course then you can worry about MPC (miles per charge). I guess what I’m saying is “IT’S A PART OF DOING BUSINESS”.
To quote Peter “RIDE MORE, WORRY LESS”! Very sound advice.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Personally, I am concerned about mpg only on longer trips in the southwest. Certainly cost has become a factor, but mostly it's about being able to plan fuel stops.
I think the original intent of the thread has been lost. I think the OP was trying to find out if there is any correlation between octane rating and mileage (I don't think there is, based on earlier discussions) to justify the higher cost.
2014 RTL Platinum
A quote from BRP web page:
For Spyder models, your machine will perform to its highest potential and best performance on 91-octane fuel with no ethanol. That said, you will not damage anything if you use 87-octane fuel with no more than 10% ethanol, it just won’t perform top its full potential. Ryker models perform well on 87-octane fuels. Do NOT use E15 or any fuel with more that 10% ethanol in any recreational vehicle as this will damage the engine.
With my 2020 F3L I am getting 38-42 running 91 premium, ethanol free. Usually Shell, Sinclair or other top tier brand. I do not use ECO mode.
David Petrick
Certified Professional Photographer
2014 RTS with Stage 1 flash and modified intake------- 38 to 40 with 91 octane fuel. There are SOOO many variables for fuel milage though, speed being one of the largest.
Lew L
I consistently get 2-3 mpg better using ethanol free gas versus 10% ethanol. That said, I get as low as 29sh mpg at 80mph across SD I90 with all my luggage installed. With the same luggage at slower 50's mph, I get mid 30's. No luggage/locally, I have no problem getting near 40mpg. This is with my Fuel Moto tune installed.
2022 RT Sea To Sky
I have a lead hand so I'm happy to get ~30 MPG on my RT Base using (mostly) 89. I measure my enjoyment by G-forces, not MPG.
35 MPG
I have always used the least expensive 87 gas available which is typically either Rebel or Arco
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
I burn mid-grade E-10, ride mostly one-up, not heavily loaded, and use cruise-control everywhere (to not aggravate my arthritic hands).
Life of vehicle (109,000 miles): 37.35
Last 6,500 miles: 38.20
Last 9 tankfuls: 39.27 ..... (Because of my new K&N Air Filter? I dunno.)
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
In all my 1330's (three now), I get on average high 30's in all three. A couple of times....low 40's. I check almost every tankful.
I do not use the mpg stuff the bike puts out. I zero the trip meter at each fill up, fill to the same level each time, and divide miles driven on the tank by gallons to fill. I use 87 with 10% ethanol. I have been using low octane for many years now and have noticed NO difference in operation or mileage when I quit using premium. About 2015.
Also had 4 998's. Always used premium in them. Mileage was in the low 30's. About 10 mpg lower than the 1330's.
There have been a few threads about low octane vs. premium, performance vs. mileage. All are interesting reads. My bottom line is printed above.
2014 RT SE6, stage II, K&N air filter, cat delete with baffle, and factory muffler 38/40 MPG. I use ECO most of the time. Run 91 all the time and have bumped 45 MPG a couple of times and 33 MPG a few times. Right now I'm tracking long term MPG by averaging figures over a month or two and see how MPG changes if any. Something I noticed popped up but I can't confirm it yet, is that I'm possibly getting better MPG at 65 MPH than I was at 60 MPH. The 1330 seems to run smoother and quieter at 65 than it did at 60 before the stage II upgrade. Could wishful thinking or just imagination. I'll have to keep on tracking my MPG to figure that one out.
Running premium exclusively for 3 years and almost always on secondary roads (not interstates) I always got 40 MPG. .....Jim
Semper Fi
my 2011 RTS got 33.7 last week only time I have really checked it . my bike is completely stock , riding 1 up . average speed 55 to 65 & mostly local highways. High Test Fuel . only has 17,600 miles on it . Ride On !
SpyderLovers Ambassador
Fuel MPG
...I agree with you on that mileage thing. You get what you get by the way you run/ryde your Spyder..
I have gotten up to 40mpg but my normal is around 30 - 32 mpg.
Ryde and Enjoy your Time.
Stay Healthy. ......
ENJOY YOUR LIFE WITH A SPYDER
