Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    May 2018
    Chateauguay, Qc, Canada
    In the U.S. Fed. DOT regs identify Car tires and wheels / rims by the rim profile .... and they are listed as " J " ....same as the Spyders we ride ..... JMHO .... Mike
    So using that sort of logic we are alowed to run Kendas on our automobiles/cars.
    Kenda has however eliminated that possibility by designating their tires as "motorcycle" tires hopefully preventing people from hurting themselves and others thru the use of an inappropriate tire.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
  2. #27
    Quote Originally Posted by Little Blue View Post
    Well, not the best tires to use. BRP is in control over the Tires shipped on your Spyder. Once you get your Spyder you can do as you please about the Tires.
    My local dealer will 'ONLY INSTALL BRP APPROVED TIRES '.
    So I am stuck with Kenda.
    Have a Blessed Day. ......
    And thank you for mentioning that some of us use OEM tires because we "have" to. Many cannot get down on the ground to change out tires themselves. Many are not physically able to do the job. Many do not want an "unauthorized" mechanic even touching their Spyder. Fronts are not much of an issue, but many look at changing out the rear tire as a formidable task. My dealers would NOT put anything but Kenda on the Spyder. I got Federals from an independent, but last time, they only had Kenda.
    Dec 2015
    Oakley Utah
    I have edited my original statement from "demeaned" to "criticize." I felt "demeaned" was a bit on the strong side. My bad there.
    Semantics, I guess. Mike is right in assuming you were talking about the person when using "demeaning". Maybe 'denigrate' or 'disparage'?
    2014 RTL Platinum
  4. #29
    Quote Originally Posted by Eckhard View Post
    Well using " LOGIC " can get you in trouble...... Kenda tires won't support the weight of even a " Smart Car " ..... and the Kenda tires that are sold for the Spyders arn't really " Motorcycle " tires .... and we know this because imprinted on the sidewall it's stated For " SPECIAL " Motorcycle use only, .... I have the feeling that you enjoy being Argumentative, so I'm ending conversing about this topic with you ...... Mike
  5. #30
    Jun 2016
    Harrington, Australia
    Actually, Eckard, they have not designated them as “motorcycle” tires, but as “Special Motorcycle Use Only”, so people won’t try to mount them on their motorcycles OR cars.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #31
    Sep 2017
    INDIANA, USA
    Default Tires Tires Tires
    ....I can remove the Spyder front tires and have them changed out.
    The Rear Tire is the problem. I do not have the strength to get.... ....the rear tire off and on.
    ENJOY YOUR LIFE WITH A SPYDER
  7. #32
    Jun 2016
    I wouldn’t use a car tires as I don’t ride a 3-4000lb car but a 1400lb motorcycle. Major difference in tire rubber.
    The issue with that “1400lb compared to 3000-4000lb so don’t run car tires” theory is that Harley does indeed run those 3000lb-4000lb car tires on their trikes as stock, Flamewinger. Their trikes are a similar weight to ours, and the Harley rears come equiped with off the shelf car tires, running at 26psi (most riders run them lower than that, but apparently there is some kind of legal limitation that prevents Harley from specifying a lower psi). Harley riders swap tire brands constantly to meet their own personal requirements with zero issues, despite “running tires built for use with 3000-4000lb vehicles”. That theory is a furphy
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  8. #33
    Pete
    Thank you for reminding everyone here about this Fact ...... I have been posting this bit of info for over 5 years ......Mike
  9. #34
    Dec 2015
    Oakley Utah
    I'll be at that point myself soon. Not sure what I'm going to do then, as my dealer stopped selling and servicing Spyders.
    2014 RTL Platinum
  10. #35
    Aug 2013
    SF Bay Area
    Pete
    I use the 3-4000 lb because that’s what the General Altimax is designed for. We don’t ride anything that heavy. Take 2/3 weight off and you loose traction. Not something I want to experience.
    2021 F3 Ltd , Magna Red
  11. #36
    Jun 2016
    So you are saying that Harley trikes, that come equipped with stock car tires, lose traction, Flamewinger? That just doesn’t sound right
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  12. #37
    Dec 2013
    And it's not right Pete . ALL car tires are designed to work well (at the appropriate pressure) for loads UP TO their indicated Maximum Load limits (that's why they're called a MAXIMUM load limit & not a 'load range' or the 'only load permitted'!! ) you just need to use a lower psi as applicable to suit the lower loads in order to maintain their traction levels! But it's not really worth arguing about it any further - there's none so blind as those who will not see!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  13. #38
    Sep 2017
    Durham,Maine
    Tires and oil, tires and oil!!!! Let's see some nice pictures of some places you guy's have been on these great car tires!!!
    2012 RTL , Pearl
  14. #39
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Best I can do - if you're close to S.C., I'll help pull the wheels and help get them to whatever shop you choose.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
