Results 1 to 8 of 8
    Aug 2018
    north wis
    Default Anybody found a cure to Bluetooth locking up? 2018+ Spyders
    I know I'm not the only one experiencing this, I've seen it in other threads. Bluetooth music works fine for 11/2 to 2hrs and then the music stops and you are locked up! You can move the on screen selector to FM but it won't work. Only answer so far is to pull over, shut down, and restart. Had bike checked for needed updates and none. I did notice the last time that my independent gps plugged into glove box usb, it showed the lost power message at same time the tunes stopped. I know it's not a real common problem cause I don't see a lot about it, but it did it on my 18 and now on the 20. Different bikes, different phones, same issue. Anybody found a cure? Android phones btw.
    Last edited by Peter Aawen; 06-21-2022 at 05:00 PM. Reason: Briefly stated question in the title, & added spaces after ,'s & .'s ;-)
    2020RTL
    Jun 2021
    OR
    Go in to the battery manager, find your music app and set it not to go to sleep.
    2021 Syder RT Limited
    Aug 2018
    north wis
    I will check that, thanks. Seems to me tho that I can play on other bt devices with no time limit but worth a check for sure!
    2020RTL
    Oct 2016
    Faribault, MN
    Quote Originally Posted by shardt View Post
    Daaaayyyaaaammmmm Can't believe I didn't think of that, I was so bummed my music would cut out while on long road trips and never thought it was the phone's battery management....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Bossier LoUiSiAna
    Similar with phones used as iPods set lock screen to never. (At least pre 18 with cable plug in)
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2018
    north wis
    I did disable my phones battery management but the u tube music app has it's own optimizer that I couldn't. None the less I did do a 2hr ride yesterday and the tunes stayed on! Thank you!
    2020RTL
    Nov 2016
    Colorado Springs
    I never found a way to recover the bluetooth once it locked up. I pulled to the side of the road several times and tried for 30+ minutes. I would eventually have to turn the bike off and on to recover. It really sucks when you're in a group ride - "Hey can everyone pull over while I reset my audio.......again!", or heaven forbid, I ride for a few hours without muisc.
    Eventually I gave up entirely on the BRP audio system. I just pair my headset straight to the phone and got allot of great benefits.
    1. Turns on much faster without the bike involved
    2. Driver & Passenger get separate audio streams (aka I don't have to listen to country).
    3. Get to continue listening to music when I stop to gas up
    4. Sena voice recognition triggers work (bike bluetooth didn't pass them on)
    5. Dependable
    2019 RT Limited
    Aug 2013
    SF Bay Area
    Just do a YouTube search for “Bluetooth connectivity problems” and you’ll find all kinds of Bluetooth issues with not only iPhones but also with Androids. I have learned to shut my phone off once or twice a month and I rarely have problems.
    https://m.youtube.com/watch?fbclid=I...u.be&fs=e&s=cl
    2021 F3 Ltd , Magna Red
