Results 1 to 19 of 19
    Jul 2021
    Virginia
    Default Radiator fan will not turn off
    While riding my 21 RT yesterday I noticed that the radiator fan did not shut off after I turned off the trike. It sat in front of my house for a couple of hours when I finished riding, and the fan never cut off. When I went to start my RT it would not start, so I disconnected the battery. Today I connected the battery back and the fan turned on again. So disconnected and pulled the battery out so that I could charge it. Any ideas on what the issue could be and how I could fix it? Thanks.
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by On3Wheels View Post
    Cooling Fan relay sticking on located in fuse box…..check your owner manual for location.
    2019 F3L , Covid Blue
    Dec 2020
    Hartwell, Ga
    And unless you're real close to a dealer it might be better to just replace it yourself if it's the Bosch type relay. Take it to a auto parts store and they should be able to fix you up with one.
    Jul 2021
    Virginia
    Cool, thanks! I'll do that tomorrow.
    Jul 2021
    Virginia
    Just to let you know, that was the issue, and the fan is off. Will keep an eye on it to make sure when the fan kicks on, that it shuts off like it should. Again thank you, thank you, thank you. Thought I was gonna be parked for a few weeks.
    Feb 2012
    Spring City,Utah
    Keep the old part, make an appointment with your dealer. When you take it in, reinstall the old part and let him find and replace it under warranty, keep the auto parts store one for a spare.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2015
    Spring Grove, Illinois
    I'm 3000 miles from my tech software... I can't figure out which relay in fuse box is the fan relay....please advise...
    Nov 2015
    Chardon, OH
    So Spyderups, what model (I assume it's an RT) and year are you talking about? Besides, aren't they labeled on the fuse box cover?
    Doug
    ”Freedom is not a loophole”
    Feb 2022
    New Zealand
    Quote Originally Posted by Spyderups View Post
    I'm 3000 miles from my tech software...I can't figure out witch relay in fuse box is the fan relay....please advise...
    Well, for my 17 F3 they are in here, all clearly labeled. Gotta remove the insert. Added its the frunk.
    Nov 2015
    Chardon, OH
    This being the RT forum, I'm thinking it's an RT. But, you just confirmed for me that the labels are still being put on the fuse box covers. Thank-You. Not sure why he's having the problem, then.
    Doug
    indpls in
    its the 50 amp or at least thats what fixed mine
    indpls in
    you can pull the pink fuse right lower of left side fuse block
    indpls in
    any luck ?
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by fatboy View Post
    any luck ?
    See post # 5
    indpls in
    see post 7
    Dec 2020
    Hartwell, Ga
    see post 7
    My bad I was going by the op's question and didn't notice someone was piggybacking on it.
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    May I ask where is the relay?
    Had the same issue, after unhooking of the positive cable and sat overnight all is well.
    Took ot to the dealer,no codes,put on computer, fan kick on and off at the appropriate time.
    Still nervous.
    Feb 2020
    illinois
    Happened to me while on trip going through Galveston area last summer with my 2020 RTL. Stopped in parking lot and tapped on fan relay and quit. Did not happen again and that was over 12 months ago.
    indpls in
    Quote Originally Posted by sgerksinwi View Post
    May I ask where is the relay? ......
    It's in the fuse block
