Results 1 to 11 of 11
    Apr 2019
    Port Charlotte Fl.
    Default Trying to replace my Dps - can anyone help?
    I am trying to replace my dps module can anyone help. Its a 2013 Can Am Spyder Rt. I have the front end off, the steering shaft I'm having problems with....
    Dec 2013
    I doubt there's much anyone can do apart from telling you it's not a massively hard job, but the DPS is something you need to replace as a unit, and once installed, it'll need to be 'recognised & calibrated' by BUDS/BUDS2 before you can ryde - BUT, it'd really help to know what year/model Spyder you have?? It's a good idea to include at least the model & year of your Spyder in your signature line so that every reader can see at a glance what you are talking about. If you try to do that & have troubles, drop me a PM & I'll help sort it for you.
    That said, the avatar pic on your profile is of a yellow 2013 RT, while the Forum section you've posted this thread in is the GS/RS Sport under General Discussion section.... Should it really be in the RT Shop Talk section?? . If so, tell me & I'll move the thread for you.
    Sorry to be of such little help with your problem, but get the sig line & model/year & sorted & maybe others will be able to use that to help more!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Apr 2019
    Port Charlotte Fl.
    Thanks, Im having a hard time here. I have a 2013 Spyder RT. I have the front section off. I see the steering shaft that is hard to reach. I'm not sure how much I have to remove to get this thing out...
    Quote Originally Posted by dave0126 View Post
    Thanks , Im having a hard here. I have a 2013 spyder rt. Ihave the front section off. I see the steering shaft that is hard to reach. I'M not sure how much I have to remove to get this thing out
    Dave .... the last I checked the DPS was around $1400.00 just for the part .... I found my DPS on an 08 GS ( V-twin also ) it was on the right side .... good luck ... Mike
    Nov 2015
    Chardon, OH
    Hey Dave. For 25 bucks you can download a full shop manual and have it in hand within minutes.
    Scroll down to 2013 Master Collection.
    https://canammanuals.com/can-am-spyder-manual.htm
    Doug
    ”Freedom is not a loophole”
    Mar 2019
    NEBRASKA
    May I ask what you paid for your DPS unit? New /Used?
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Quote Originally Posted by davev1pa View Post
    Dave if you are asking me ????? .... I didn't pay anything because it was done under warranty - shortly after I bought it ( Used ) .... Mike
    Mar 2019
    NEBRASKA
    I'm asking DAVE0126
    I'm asking DAVE0126
    OK ..... PS using " Reply With Quote " will eliminate this error ...... Mike
    Apr 2019
    Port Charlotte Fl.
    Default Removing a DPS modual
    Removinng a DPS on a 2013 spyder rt. Having problems removing steering shaft lookimg for help
    2013 Spyder RT
    Mar 2019
    NEBRASKA
    https://www.youtube.com/watch?v=kIG-2CZaeag
    https://www.bing.com/videos/search?q...BC2B&FORM=VIRE
    Last edited by Peter Aawen; 06-29-2022 at 02:49 PM. Reason: Merged immediately following post that quoted preceeding post.... :-/
