Results 1 to 4 of 4
    Default Radio ...Signal issue on 14 RT
    ... I no longer get ... AM ... signal ( FM is fine ) ... what I see on the screen is FM, NOAA, & Aux. ... instead of the normal AM signal it is showing either ... SW .... or ... SL ???? ... Yes I have been thru the programming for Audio and I can't fix this .... I even went into the " REGION " section, and tried all of them .... still NO ... AM ..... HELP ...... Thanks .... Mike ..... PS, the antennae is not the problem I get FM fine
    SoFlo
    Our 2014 radio got stupid before. I pulled the fuse for ten minutes, reinserted the fuse and it reset to normal.
    Thank you .... I'll try that ..... Mike
    Jan 2019
    Crofton, KY
    About a year and a half ago, I had trouble with my BRP CB. Absolutely nothing. I went into the
    menu and adjusted everything I could think of, all to no avail. A few days later, I disconnected the
    ground wire from the battery and left it off for a couple of days. Lo and Behold, after I reconnected
    the ground wire, my CB was back to working as it should. I don't know what happened, but I
    suspect that, for some reason or another, the computer brains in the bike was not recognizing that
    a CB was there. Haven't had any more problems since then. I have a 2014 RTL.
