Results 1 to 3 of 3
    Mar 2020
    Western New Mexico (Thoreau)
    Default Right side floor board front bolt not installed on assy! Anyone else? Solutions?
    I have a 2021 RT Limited and was performing its second oil change. I have to take out the brake pedal spring and bolt to make it easier to remove the trans plug? Did not notice on first service, but while putting bolt and spring back onto the brake pedal, I noticed the front floorboard bolt was not there!
    I’m thinking the brake pedal must have caught on the bolt, so when the bike was assembled, they just left it out? A regular bolt would hit, anyone else have this issue and/or a solution?
    2021 Spyder RT-L - Asphalt Grey
    • Vredestein tires all around
    • Rolo Laser Alignment
    • Lamonster tire balancing rings/front
    • Lamonster Sway Bar
    • Lamonster belt tensioner
    • K and N air filter
    • Rear cowl - in place when you remove rear box
    Bossier LoUiSiAna
    Hopefully warranty
    Mar 2020
    No warranty in this case, bought bike from Imotorsports in Chicago. The closest dealer for me is in Albuquerque, over a hundred miles each way!
    I was just checking with the site to see if this was a common instance on the newer 20+ Spyders? I got online and ordered the right bolt and washer for the right side floorboard from Can-Am Partshouse, price+shipping under $16.00! I will just add some blue lock-tite and replace it. Hopefully just an over site on assembly and no issues with foot brake lever! Thanks for your responses.
