Results 1 to 6 of 6
    May 2022
    Tennessee
    Question Headlights Stopped working!! Any fix ideas/suggestions?
    I don’t ride a lot at night so I do not know when this actually started. Both front headlights and mirror running lights are not working. There is also no actuator noise when toggling the HI/LO switch. I have checked the fuses and relays in the frunk and under the seat. Voltage shows 14v at idle. Not sure where to dig in next. Only electrical mod I have done is adding the LED strips to the fenders and replacing the fender running light bulbs with the appropriate LED bulbs.
    Thanks in advance!!
    2011 Spyder RTS
    ****UPDATE*** Making progress! Swapped relays around and got the headlights to work.
    Dec 2015
    Oakley Utah
    I think there is a relay for the headlights. I don't know that model though.
    2014 RTL Platinum
    Aug 2021
    VA
    I am curious, Did you get the mirror running lights back?
    INDIANA, USA
    Default Bad Relay ? ?
    Quote Originally Posted by erinfire703 View Post
    Thanks in advance!!
    2011 Spyder RTS
    What was your final fix?
    A bad relay(s)?
    Corrosion on the contacts?
    Or something else?
    Thanks for the Heads Up. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2022
    Texas
    I have a 2012 rts same problem no headlights tried relay swap check fuses no fix. What’s next
    Quote Originally Posted by swbmagnum6 View Post
    Do hear the shutters clunk when you switch between hi and lo?
Tags for this Thread
