Results 1 to 15 of 15
    Active Member peterparker's Avatar
    Jun 2014
    The Woodlands, Texas and Pipe Creek, Texas
    Default Baja Ron bar or Cat delete for 2020 RTL?
    Trying to decide which farkle to add on first. A Baja Ron sway bar or a cat delete. I don't want to do both at the same time because my income is a monthly social security check. Since it is really hot right now in Texas, I'm kinda leaning towards the pipe. Whadaya think?
    Bill
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by peterparker View Post
    Bill
    Truly an "Almost life & death decision", Do you have more need for speed in the corners or noise in the exhaust? Turn up your radio and hearing aid and go with the new Baja Ron bar is my "Final answer"!...Bill
    If in Doubt, Don't Do It!
    Apr 2022
    SC
    I’m going the BajaRon sway bar first. Pipe comes later. BajaRon brand definitely. The exhaust I haven’t made it my mind yet. I had a Two Brothers on a 2013 RSS. I loved how it sound.
    Oct 2015
    Lynden, WA
    Are you looking for performance or comfort?
    Go with the BaJa Ron Bar first. It has a demonstrable immediate riding effect.
    The Cat Delete is not as definitive in performance changes but does offer some comfort advasntage.
    I have both on my Spyder.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Better to ask Ron if he has a bar for your Spyder in stock.
    T.P.
    Mar 2015
    forrest above Reno, Nv
    I think the anti-sway upgrade will make you smile more than the noise. The bar was one of my earliest farkels. Still have the stock pipe.
    Last edited by Peter Aawen; 06-19-2022 at 07:49 PM. Reason: ...than more the... ??? - .....more than the... ;-)
    2014 RTS , Circuit Yellow
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Bill
    I added the BR swaybar first, then 2 years later, the RLS cat delete.
    Honestly, I think this is the preferred order ....
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Exhaust will be noticeable 100% of the time, bar mmmmmm...........?
    Apr 2022
    SC
    One could save your life…the other pee off your neighbors.
    Dec 2015
    Oakley Utah
    Default One is an important upgrade and the other a farkle
    Guess which is which.
    2014 RTL Platinum
    Sep 2015
    Chilliwack, BC. Canada
    I’ve done both, and which one first is arbitrary. You mention the heat in Texas right off the bat, so I’m thinking that the ambient temperature coupled with the temperature from the cat is bothersome to you, so I’m leaning towards the cat delete. I know that made a real difference to the heat generated to my saddle. The stock swaybar is adequate and safe, but makes cornering more stable. Your comfort can mean the difference between going for a ride and not going for a ride. YOUR CALL
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    I put the sway bar on right away and put a cat delete pipe on a month ago, I removed the cat delete yesterday. The exhaust fumes were more then I am prepared to handle. Plus with the stock muffler, the sound wasn't really noticeable, my wife didn't realize I had replaced anything on the exhaust so to her it made no difference. Chris
    2021 Spyder RT Liminted , Marsala Red in Black
    Sep 2018
    Australia
    Quote Originally Posted by GeorgeXP700 View Post
    What happened to ''loud pipes save lives'' and all that? Pretty crumby neighbours that would dispute the sweet sound of an RLS cat delete on song.
    Meanwhile back at the decibel test centre.....................
    https://www.youtube.com/watch?v=0tNhw0Rio9s
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    I have done both. Definitely more bang-for-buck with the sway bar. I am hoping the cat delete will reduce heat when it gets really hot here, but time will have to tell. In terms of sound, there is no real difference. (I installed an RLS powder-coated pipe, so it is baffled). It fit beautifully (and easily) and there is no increase in fumes. I lost some weight, hopefully some heat and am using a Power Commander 3 and a tune that takes the cat delete into consideration. Bike runs great. Louis at Dynojet Reseatch (Powervision) is very responsive and helpful.
    2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
    2021 RT Limited , Marsala Red/Black
    Jun 2014
    Thanks everyone for the replies, even the smartazz one. One thing I value is being able to ask questions on here and then read the different replies.
